Rods "Spaceship" Scratch built Plasma Cutter build
7 years 9 months ago #124801 by rodw
Well, I did a bit more digging with a multimeter while cutting and found the divided voltage at the THCAD input was measuring in the millivolt range when it should have been around 4.3 volts according to the book specs. I had a good chat with the supplier who was very helpful. The most logical reason was that the standard CNC board on this machine without a divided volts output was fitted. But I opened the inverter again and confirmed the board fitted was the Automation Interface with Divided voltage output by the part number. I found my busted THCAD board and removed the input socket from it so I will wire it into a multimeter and check the voltages without it connected to the THCAD as I've been caught with divider boards before! I'm sure I'll sort it out pretty quick.
7 years 9 months ago #124805 by rodw
Just on a side note, while I was browsing through the forum, I had a BFO (blinding flash of the obvious) about how I do homing with my prox switches. I use these sensor plates at each end of the X and Y axes
image missing https://i210.photobucket.com/albums/bb270/rodweb/Lathe/Plasma/DSC_7216_zpsbdxutqhf.jpg
When I started out, I don't think many people were using master branch but I started to use it to get the joint axis gantry homing. I think it was some of the recent comments by Andy that made the penny drop.
Every now and again, I have noticed the X axis get confused when homing and now I realised that if the home switch sensor was over the flat plate at the max limit axis end, it thought it was close to the home switch so it moved the wrong way in an attempt to move away from the home switch.... So my machine design is wrong. I need to reverse the sensor plates at the max limit end so the max limit can be adjusted but the home sensor is never triggered at this end of the gantry. And here was I thinking how cool my home/limit switch sensor set up was for the last 2 years!
7 years 9 months ago #125042 by rodw
They don't make it easy for you. I had problems earlier in the week getting a voltage into the THAD board. So after a good few hours this morning starting with a 9 volt battery, wiring in a multimeter, reverting to raw arc voltage and adding the appropriate scaling resistors, the problem was the polarity of both the raw arc voltage and divided arc voltage were reversed from both the manual and the diagram on the machine itself. This is the second machine I've had with incorrect documentation.
This looks about right. 126 volts vs book setting of 131 volts for this cut
So now a question for PCW. With the 30:1 divider selected, the THAD is hitting its full scale briefly at the beginning of a cut. You can see that in the halscope plot above. Is this anything to worry about or should I change the divider settings so it stays in range?
7 years 9 months ago #125071 by PCW
You can overrange the the THCAD10 input 50X (500V) continuously so there's nothing to worry about. As a matter of fact, overranging the input is a valid way to get a bit better resolution if you dont expect to run the height control at say >200V
7 years 9 months ago #125091 by Grotius
Hi Rod,
Nice to see you cutting again. Keep up the good work !!
7 years 9 months ago #125127 by rodw
Well, I had a bit of a play today with the external offsets branch.
This was as good as it got.
I took a video of it cutting with these settings, I played around with velocity and acceleration settings as well. I'll podt the video from my phone shortly and you guys can tell me if the Z axis is too busy....
Time to create page: 0.913 seconds
