rodw wrote: So for now I am going to keep working on the experimental Axis GUI of Dewey's so there are no settings required.
islander261 wrote: Rod
Glad you are making some progress. I use a single switch for my Z+ limit and homing and am using Gmoccapy UI. Homing offset works just fine and is about 11mm down from Z+ limit. What examples do you want to see?
I haven't needed to change my Z PID settings for different material thicknesses or types.
I remember when we found out about the TP not providing the Gcode F value all the time. I took a different approach because I think what actually matters is the commanded velocity at the start of the corner hold condition. What I do is save the commanded velocity at the start of the corner hold and use that value to determine when to release the corner hold. That way if the TP commanded velocity value changes during the hold, usually reduced, the corner hold isn't released while the torch is still moving slowly. That is how I found the problem in the first place.
It is usually much cooler here with lower humidity and I still use all of the tricks to keep my cutting air dry. Cooler between last compressor stage and volume tank, automated tank drain on low point of volume tank that runs every cycle, Copper pipe cooling run with water trap leg before air enters building, then a refrigerated air drier and desiccant bead filter on the plumbing leg to the plasma cutter.
It is a balmy -4C here today with steady 50km winds gusting to near 100km. Blew an 20m tall pine tree down in our front yard last night. Salt spray freezing as it blows across the road.
Another Axis GUI that i do not know about ???
