Mazak Micro Slant 15 Retrofit
- smc.collins
- Thank you received: 139
20 Mar 2023 22:36 #267189
by smc.collins
Replied by smc.collins on topic Mazak Micro Slant 15 Retrofit
do you have the same turret mechanism on your machine ? if not what are the differences ? I will just make 2 separate programs with the needed revisions if that's what is required. As to the language, I am really tired of people preaching broken adhoc solutions to stuff. Drives me bananas, Yes I know I can string together five programming languages to scratch my head, that doesn't mean I think it is a good idea.
- Online
- Thank you received: 7491
20 Mar 2023 22:49 #267190
Replied by tommylight on topic Mazak Micro Slant 15 Retrofit
Been a while, but mine should have a hydraulic cylinder for locking/unlocking the turret, an AC dual speed motor to turn the turret, 12 tools with 6 boring and 6 normal side tools.
Inputs to turret from Mesa:
Unlock turret
spin turret at speed 1
spin turret at speed 2
(not using speed 2, it is to fast for anything usable, i might try to do some hal stuff to use it later)
Outputs from turret to Mesa:
12 separate pins for each tool (this did require some hal stuff as there are empty spaces between each tool signal)
Turret locked
All those pins also go through the existing relays and interlocks, so might or might not still need something, but i doubt it.
Unlock turret
Turret locked
21 Mar 2023 12:57 #267226
But once you start to try to make a component to handle more than one toolchanger, then the configuration options multiply, and the problem comes back.
The carousel component only tries to do part of the job, and even that is now so complicated that I think that I am going to have to write a full manual page for it. (Actually, what is probably needed is a page on toolchangers in general, describing all the options)
Unless you plan to take on the job of writing custom components on request for each toolchanger as they appear on the forum then I don't think the "dedicated component for each changer" is workable.
For my own toolchanger (If I had one) I would probably write a custom component, but even then I might end up calling it from a G-code remap just to be able to handle fault cases.
If the tool change process involves axis movement then you _have_ to integrate G-code into the system, you can't move axes from a HAL component.
To take the case of Tommylight's "pin for each position" changer, this is handled by the development version of carousel. The released version doesn't do it properly in all cases because (unless there is a Geneva mechanism) the tool changer doesn't stop when you stop the motor.
If you want to write a custom comp for this, then the current carousel behaviour is:
When a new pocket request is received
1) If not homed, turn on the motor and rotate until the home pin is seen. Reset the pocket counter to 1
2) If the current position is not the current one, choose a motor direction and count the position pins as they pass
3) When you see the correct position pin, stop the motor
4) Wait a programmable time for the motor to stop.
5a) If the pin is still at the sensor, back off at slow speed until it is not: Go to 6)
5b) If the pin is not at the sensor, back off at slow speed until it is. Go to 5a)
6) Move forwards at slow speed until the pin is at the sensor.
At this point the carousel component reports "in position" and expects clamping etc to be handled, and then the "iocontrol.0.tool-changed" pin to be set to indicate that the change is completed to the core system.
For some changers with a locking pin, you would either)
a) Operate the locking pin when 1 position away from target, wait for it to drop. Check the position sensor
b) Switch to slow speed when 1 position away from desired and wait for the locking pin to drop
c) Wait for the desired position, set the pin and reverse at slow speed until the locking pin drops.
Your components should really try to handle fault cases. (failure to clamp, failure to unclamp, pocket not found after a long period of looking)
The G-code (ABORT, ....) command is one fairly neat way to do this because it automatically calls the ON_ABORT routine from the INI file.
A HAL component can send messages to the user too:
linuxcnc.org/docs/stable/html/man/man3/rtapi_print.3rtapi.html
For example
I don't know of a way to trigger an abort from a HAL component, however. Which is not to say that there isn't a method that I don't know about.
Replied by andypugh on topic Mazak Micro Slant 15 Retrofit
I actually agree with you to an extent, in that a single toolchanger component for every toolchanger variant would be easier for users to set up.the answer is a suite of hal.conponents to run the tool changer in 1 file long term but that's bot going to happen without the effort part.
For example
rtapi_print_msg(RTAPI_MSG_ERR, "Opps, that wasn't meant to happen")I don't know of a way to trigger an abort from a HAL component, however. Which is not to say that there isn't a method that I don't know about.
21 Mar 2023 13:00 - 21 Mar 2023 13:02 #267227
Oh, I forgot to mention, it is very important to debounce the position sensor pins with this kind of changer feedback. In fact something rather cleverer than a debounce would probably be better, based on the expected time intervals between pins being sensed.
Last edit: 21 Mar 2023 13:02 by andypugh.
- smc.collins
28 Mar 2023 20:52 #267730
by smc.collins
Tommy here is the modified component for some one else's MazakQT15, 8 position etc. LMK if this works for you. If not I am open to modifying it.
- smc.collins
28 Mar 2023 20:54 - 28 Mar 2023 20:55 #267731
by smc.collins
I can expand the program I have for the turret, 1 at a time, until I have a broad enough range of code to figure out how to rebase and refactor it. then it will probably just require say 4-6 hal components. There are basically 6 types of tool changers, broadly speaking. those programs could be simplified. Alternatively, having predefined toolchanger programs could make users refit the machine accordingly, bring the hardware to the software, to a degree
By that point, there should be enough code for others to pickup the work. If not, I will start charging money for custom programs.
Last edit: 28 Mar 2023 20:55 by smc.collins.
- Online
03 Jul 2023 23:29 #274719
Went to the shop No1 for a smoke, watched the sad Mazak covered in dust, so gave it a bit of thought, for now.
Not sure when i will have time to go back to it, but i am getting close, hopefully.
I might:
-remove the Mesa 7i84 from the control panel and replace it with a 7i73, i have one
-i need more inputs for the foot pedals that open/close the chuck
-tidy up the wiring, do the power stuff as now there are 3 sockets powering everything
-program some interlocks to prevent moving the back parts if the toolhead is to low, prevent using round tools if the part is held on the back side (probably the first option will take care of this)
-program the panel buttons to go through those interlocks
-maybe paint it other colors?
Yeah, i still need to find a hydraulic chuck for it, new was 7900 Euro a few years back, i can not afford that.
Finding a used one proved to damn hard, although i did find one once at something like 700 Euro (can not recall) and asked a friend to get it for me, but he did not !@#$%^&*()
I wish i could sent it to RotarySMP to have it cleaned properly, together with some toothbrushes!
I might:
- Masiwood123
- Thank you received: 93
04 Jul 2023 11:08 #274733
by Masiwood123
Replied by Masiwood123 on topic Mazak Micro Slant 15 Retrofit
novi.kupujemprodajem.com/alati-i-orudja/...?filterId=3492201570
Pogledaj da li ti ovo nesto odgovara mogu da pitam za cenu..
- Online
04 Jul 2023 18:25 #274770
To small, i think i need a 250mm one, with a center hole.
Thank you very much for everything.
Hvala ti puno, za sve.
The following user(s) said Thank You: Masiwood123
- Masiwood123
04 Jul 2023 19:33 #274780
by Masiwood123
i assumed, ok, if i come across something on the ads, or auctions, will let you know... greetings
Time to create page: 0.137 seconds
