Mazak Micro Slant 15 Retrofit
3 years 3 months ago #274719 by tommylight
Went to the shop No1 for a smoke, watched the sad Mazak covered in dust, so gave it a bit of thought, for now.
Not sure when i will have time to go back to it, but i am getting close, hopefully.
I might:
-remove the Mesa 7i84 from the control panel and replace it with a 7i73, i have one
-i need more inputs for the foot pedals that open/close the chuck
-tidy up the wiring, do the power stuff as now there are 3 sockets powering everything
-program some interlocks to prevent moving the back parts if the toolhead is to low, prevent using round tools if the part is held on the back side (probably the first option will take care of this)
-program the panel buttons to go through those interlocks
-maybe paint it other colors? :)
Yeah, i still need to find a hydraulic chuck for it, new was 7900 Euro a few years back, i can not afford that.
Finding a used one proved to damn hard, although i did find one once at something like 700 Euro (can not recall) and asked a friend to get it for me, but he did not !@#$%^&*()
I wish i could sent it to RotarySMP to have it cleaned properly, together with some toothbrushes! :)
3 years 3 months ago #274733 by Masiwood123
novi.kupujemprodajem.com/alati-i-orudja/...?filterId=3492201570
Pogledaj da li ti ovo nesto odgovara mogu da pitam za cenu..
3 years 3 months ago #274770 by tommylight
To small, i think i need a 250mm one, with a center hole.
Thank you very much for everything.
Hvala ti puno, za sve.
The following user(s) said Thank You: Masiwood123
3 years 3 months ago #274780 by Masiwood123
i assumed, ok, if i come across something on the ads, or auctions, will let you know... greetings
3 years 3 months ago #274801 by smc.collins
Tommy, I have a machine tool ussd parts seller ,machine dismantler close to me.
post up the info on your chuck, I'll call around
3 years 3 months ago #275246 by tommylight
It has a plate with chuck info on it, i will take a picture and upload it here, thank you.
Still waiting for some good encoder cable, or i will have to use the existing ones from the machine.
Although i might have to remove the 7i92 and 7i77 to use on the Hurco:
forum.linuxcnc.org/30-cnc-machines/33529...20p-retrofit?start=0
they lost theirs so i ordered a combo of 7i96S, 7i85S and 7i83.
Time to create page: 0.301 seconds
