2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
5 years 10 months ago #193460 by tommylight
Did more work on the new builds, got the reductions for the Y axis ( 2 each ) fully finished, uprights are mounted, now the gantry and the belts for Y await some TLC.
5 years 10 months ago #193682 by tommylight
Mounted the rails and carriages on the X axis of both machines today, seemed like one of the rails moved a bit when i tightened it so will have to check that tomorrow.
Next is the Z axis mount and the motor/reduction assembly, belts on all axis, Z axis are ready and waiting to be bolted.
BTW, made these two a bit narrower at 1.25X2.5 and 1.5X3M due to space constraints.
Happy New Year to all ! All the best wishes.
Tom.
The following user(s) said Thank You: phillc54, shpatb, snowgoer540
5 years 9 months ago #194270 by tommylight
A quick update on the state of affairs here at the "pit", all belts are on and tightened, all rails are on, all axis are on, cabling is in place, now to wire everything and start testing and tuning.
Since no one here believes anything without evidence, here is some evidence, exhibits A, B, C, or the same thing from different angles:
Been working till 5:35AM last night in the shop, got to bed at a bit over 6, woke up at 9:45, so feeling a bit groggy, but i am off to the shop again after a full days work adding another full days work during the night, all inside of a day! Since it is raining almost every day the new shop is still on hold. Plans, the only thing sure to fail! :)
Regards,
Tom.
The following user(s) said Thank You: phillc54, Clive S, Grotius, shpatb, snowgoer540
5 years 9 months ago #194277 by shpatb
awesome job uncle Tomy, You definitely need to put an eagle there to make them look more patriotic machines :laugh: :laugh: :laugh:
5 years 9 months ago #194299 by Grotius
Time to create page: 0.597 seconds
