2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
5 years 10 months ago #193162 by tommylight
The following user(s) said Thank You: phillc54, Clive S, shpatb, snowgoer540, pinder
5 years 10 months ago #193174 by machinedude
merry Christmas Tom. Santa needs to bring you a bigger work shop :) things look a little tight in the space department :)
5 years 10 months ago #193177 by tommylight
machinedude wrote: merry Christmas Tom. Santa needs to bring you a bigger work shop :) things look a little tight in the space department :)
Go back a bit, there should be pictures of the new 108 sq meter shop somewhere, yup here it is:
forum.linuxcnc.org/show-your-stuff/38547...ild?start=240#190568
So in total that makes for 80+30+108=218sqm ! Cr@p, still not enough ! :)
There are plans to add another 70 to the shop as soon as possible. Plans, i said ! :)
Thank you very much.
5 years 10 months ago - 5 years 10 months ago #193185 by machinedude
that's way more space than i have :) my home shop is less than 65 sqm. it gets cramped when things get cluttered which is most of the time with me :) been working on the electronic in my living room at the house to avoid the mess in the shop :) i tinker so i can play around you on the other hand need room to run since your always on the move :)
i seen you were working on additions to work space but it's late in the year so weather comes into play at some point. not sure where you find the energy to move at the pace you do :) i started working on things yesterday and somehow end up playing with the granddaughter for a few hours :) i have to many distractions :)
Last edit: 5 years 10 months ago by machinedude.
5 years 10 months ago #193207 by rodw
machinedude wrote: that's way more space than i have :) my home shop is less than 65 sqm.
65!!!
Man I only have 10 sqm at home! Now 165 sqm at work is not enough!
5 years 10 months ago #193225 by tommylight
Raining, when it's not it is to cold, so the work has practically halted.
I would have gladly assembled the 2 machines in the new shop, plenty of space, now i have to do a lot of physical exercise over and under the machines to mount the gantries, rails, belts, Z axis, cable chains etc etc.
Oh Joy ! :)
The following user(s) said Thank You: shpatb
Time to create page: 0.624 seconds
