Mach3 -> Camtronics -> Parallel P Replacement
5 years 5 months ago #210164 by andypugh
rdeeming wrote: Changed to public
Nice.
Now is about the time you are likely to find that threads (to a standard) are harder than they appear. ISO metric and SAE threads have a significant flat on the threads, taking them p/6 smaller than nominal. Whitworth and ISO pipe threads have a rounding that does the same, but is harder to machine.
If you are trying to fit to an existing part, don't keep reducing the diameter of a pointed thread until it fits. If you do then the root and thread thickness will be under. Draw your thread and touch-off the tool to get the major and minor diameters right with the actual tool.
5 years 5 months ago #210170 by rdeeming
ok thank you for the heads up and info. so far I was cutting my mess to my own bad mess of threads and not matching other than initially using a die as a sanity/learning check to first fix my numbers and then figure out how much slop I needed to add to get the die to roll ok.
4 years 9 months ago - 4 years 9 months ago #233134 by rdeeming
I did finally get to the bottom of this. I was using a mini keyboard and was using (shift for some reason) 9 and 3 to move the Z axis. Not using the shift key the jog speed is normal.
Last edit: 4 years 9 months ago by rdeeming. Reason: poor grammar
4 years 8 months ago #235374 by rdeeming
Got tired of the Gigabyte Brix fan noise decided to get a better system when the garage starts to get hot in the summer etc. Picked of a Dell OptiPlex 990 and that seems to be much better.
4 years 8 months ago - 4 years 8 months ago #235375 by rdeeming
I did try and do the good fight to get FC35 Server going.
It was close but at the end of a few days I reverted back with CloneZilla and this guide which is put together really nice qtpyvcp Bullseye
With the new kernel builds there is only the need to change grub for RT.
    preempt=full processor.max_cstate=1 idle=poll
If anyone wanted to take off where I left off with FC35.   Here are my notes based off the link above for Debian plus the hacks to get around the most notable few annoyances like yapps and WC3-LinkChecker
# Install rpm fusion
dnf install
mirrors.rpmfusion.org/free/fedora/rpmfusion-free-release-$ (rpm -E %fedora).noarch.rpm
dnf install mirrors.rpmfusion.org/nonfree/fedora/rpm...on-nonfree-release-$ (rpm -E %fedora).noarch.rpm
dnf groupinstall "C Development Tools and Libraries" "KDE Plasma Workspaces" "Development Tools" "LibreOffice" "Office/Productivity" "System Tools"
dnf install systemd-devel tclx-devel tkimg-devel bwidget tk-devel tcl-devel libtirpc-devel libusb-devel libmodbus-devel gtk3-devel gtk2-devel firefox hevea alien boost-devel python3-devel readline-devel python3-tkinter mesa-libGLU-devel devscripts dialog xdotool lshw lm_sensors dialog xdotool lshw glx-utils asciidoc dblatex dvipng cpanspec rpm-build python3-pyopengl geany groff inkscape python3-xlib python3-wheeltcl-tclreadline python-sqlalchemy netcat python3-configobj
dnf install 'perl(CSS::DOM)' 'perl(CSS::DOM::Constants)' 'perl(CSS::DOM::Style)' 'perl(CSS::DOM::Util)' 'perl(Config::General)' 'perl(ExtUtils::MakeMaker)' 'perl(Locale::Country)' 'perl(Locale::Language)' 'perl(Net::IP)' 'perl(Net::hostent)'
wget cpan.metacpan.org/authors/id/D/DH/DHM/W3...Checker-5.0.0.tar.gz
tar xvzf W3C-LinkChecker-5.0.0.tar.gz
cd W3C-LinkChecker-5.0.0
perl Makefile.PL; make ; make test ; make install
dget deb.debian.org/debian/pool/main/y/yapps2/yapps2_2.2.1-3.1.dsc
tar xvzf yapps2_2.2.1.orig.tar.gz
cd yapps2-2.2.1/
python setup.py install
# Fedora update grub for RT preempt
grub2-mkconfig
systemctl set-default graphical.target
linuxcnc configure line for this
./configure --with-realtime=uspace --enable-non-distributable=yes --enable-build-documentation=Y
Last edit: 4 years 8 months ago by rdeeming.
Time to create page: 0.429 seconds
