Mach3 -> Camtronics -> Parallel P Replacement
26 Mar 2020 15:05 - 26 Mar 2020 15:08 #161572 by rdeeming
I have a Shopmaster Patriot 2011 that came with a Dell computer loaded with Mach3 and Wondoz. That sent signals to a Camtronics built unit via a C10 Parallel port interface to Geckodrive 6203V Stepper drive. The Dell PS died, the HD about died a few years back. I grabbed a new PS, used clonezilla replacing the HD with an SSD.
Because of CORVID-19 I have a huge amount of home time to do what I wanted way back then. Get rid of Wondoz.
My goal.
  • Replace Mach3/Wondoz with LinuxCNC/Mint.
  • Replace the C10 with Mesa 7i76e
I received the 7i76e card yesterday and so it begins.
I'm not savvy with non RedHat Linux variants, LinuxCNC or electronics for that matter.
This thread could get interesting.
Hopefully I escape the white smoke.
Attached is what I will be working with.
Last edit: 26 Mar 2020 15:08 by rdeeming. Reason: Added Dell pic
  • Moderator
  • Moderator
26 Mar 2020 15:19 #161575 by tommylight
Replied by tommylight on topic Mach3 -> Camtronics -> Parallel P Replacement
That should be easy enough, remove wires from BOB and attach those to 7i76E, power the 7i76E, install Linuxcnc and make chips.
26 Mar 2020 17:29 #161582 by rdeeming
Replied by rdeeming on topic Mach3 -> Camtronics -> Parallel P Replacement
Great. I am hoping so.
26 Mar 2020 17:53 #161584 by rdeeming
I downloaded the Mint variant on this forum and started guessing at the best process to install a conservative release of LinuxCNC on this thing.
The process (seems like there are 50 ways to get said point) this is my first stab at it:
  • Download a spin of Mint from one of the LinuxCNC threads
  • Threw the ISO on a flash drive from the Mac
    sudo dd if=./linuxmint-19.2.0-20200306-LCNC-2.8-RT-UEFI-mate-64bit.iso of=/dev/disk2
  • I got a little stuck here not knowing what is the best strategy.
    • git clone -b 2.7 github.com/LinuxCNC/linuxcnc.git linuxcnc-2.7
    • cd linuxcnc-2.7/debian
    • ./configure uspace
    • cd ..; dpkg-checkbuildeps
    • sudo apt-get install ... packages ... # At this point I am wondering if I derailed because I am using a custom ISO for linuxcnc installing packages
    • dpkg-buildpackage -b -uc
    • sudo app install linuxcnc-uspace
    • linuxcnc &
26 Mar 2020 18:01 - 26 Mar 2020 18:03 #161585 by rdeeming
On to the Camtronics and the C10 to 7i76e.
I made mount/(Corvid-19 Home Lock Down hack) made from materials in the garage and past projects back in the 80's...
Attached is a CAT-5 to parallel Male to a parallel Female to CAT-5 plugging into the 7i76e board.
I tested the config on the home network and it seems to work just fine.
Last edit: 26 Mar 2020 18:03 by rdeeming. Reason: Different pic
26 Mar 2020 18:16 #161589 by bbsr_5a
Replied by bbsr_5a on topic Mach3 -> Camtronics -> Parallel P Replacement
hi we got a external user that has quite a Good if not the best follow throu
gnipsel.com/linuxcnc/uspace/debian9-emc.html
look here
as you are new to the Linux system why dident you go for the almost redy to run Version on DVD Debian
just insertt the DVD and go ahed cabeling ans configurating
  • Moderator
  • Moderator
26 Mar 2020 18:16 #161590 by tommylight
  • I wonder what made you think you need to do that ? There is no need for anything under that line, just boot and use as live, or install to hard drive and start Linuxcnc.
    26 Mar 2020 18:24 #161593 by rdeeming
    I am installing from a USB thumb drive to a 64g SanDisk card. Going with no HD in the Zotac.
    26 Mar 2020 18:25 #161594 by rdeeming
    I will take a look at that.
    I am newish to Debian flavored ice cream. Kinda avoided it as much as Wondoz. Not new at all to Linux but that never means I don't learn something everyday :-)
    26 Mar 2020 18:29 #161596 by rdeeming
    I tested/verified the 5v source that was going to the C10 and sent that to the 7i76e P3 plug.
    I am now onto where I run out of talent and onto remove/replace.
    C10 has the following set on the jumpers.
    • COM 1-2 GND # I'm Ok here
    • Pins 2-9 Pull down # I honestly do not know at this time what pull down/up means.
    The 7i76e has something extra from the C10 that I am not getting.
    Pin 1 GND # I am Ok with that
    Pin 2 STEP0-
    Pin 3 STEP0+
    # I am stuck...
    Pin 4 DIR0-
    Pin 5 DIR0+
    # I am stuck....
    Step and Dir the - + option.
    I am going with +, it sounds so much better than - today.
    I wont throw the power till I understand this better.
    Any advice is totally welcome.
    Time to create page: 0.587 seconds
