- Thank you received: 2177
Motoman K6SB Retrofit
- thefabricator03
- Visitor
Aciera wrote: Have you already used EtherCAT in LinuxCNC or why did you decide to go that route?
How do you home the 6 joints? (I presume those drives don't have absolute encoders)
I found that one problem in linuxCNC is the missing capability to check for joint limits when using cartesian coordinates and non-trivial kinematics. Are you using simulation before executing the paths to check for limit violations and/or singularities?
I still have to work those things out. The motors have incremental encoders and brakes. I was thinking I save the last known position of the encoder in LinuxCNC and use that to home the axises. Dont know if that will work well or not but I will see. When I repaint the unit I will remake the home position stickers and use them to set the home position.
I plan to work with some developers and get any features I need added to create a LinuxCNC robot configuration. I hope it to be what PlasmaC is to plasma cutters but for six axis robots. I want the config to have singularity detection built in much like my Motoman controllers and also dynamics control. It will be a lot of work but I am up for it. Hope to get it working in the next couple of years depending how I go with other projects I am working on.
I have also brought a copy of RoboDK to plan out my work cells in 3D. I will use that when I get to the stage of creating programs but like PlasmaC, I want it to be able to work on its own and not be tied to any one CAM program. This will be a pretty big project but one I hope will pay dividends in the future.
Also with EtherCAT, I went that way because it is the fastest modern fieldbus. I can use it to link external axises that are spaced around a work cell with normal Ethernet cables. I have not used it so it will be a learning curve.
For a while I was working on converting that Mitsubishi arm I mentioned and got as far as working out the kinematics and how to switch between joint and cartesian modes as well as movements in tool coordinates but all just in a LinuxCNC simulation. I'm now stalled because I can't find drives that work with the motors and the encoders. STMBL drives might work but they are being redesigned.
So I play around with my other Mitsubishi robot. The vendor lock-in has dampened my enthusiasm somewhat though.
Anyway, I'm interested to see how you are going to make out with the encoders on your drives as it seems that in these robot joints the encoders sometimes have some insanely high resolution to achieve the desired accuracy.
- thefabricator03
- Visitor
But more interested in seeing how accurate is good enough. For a welding application you dont need precision of 0.01 of a mm.
- Thank you received: 7491
In some cases even 0.5 will do just fine with a 1mm CO2 wire. Tested and confirmed with a Kuka KR150 welding 2mm wall thickness 50x30mm oval tubing.thefabricator03 wrote: For a welding application you dont need precision of 0.01 of a mm.
Why the report ? Wrong button ?
- thefabricator03
- Visitor
