Motoman K6SB Retrofit
5 years 3 months ago #214375 by andypugh
Replied by andypugh on topic Motoman K6SB Retrofit
I think that the STMBL might work with your motors. But the difficulty is getting a set of STMBL drives, especially with the current chip famine.
The following user(s) said Thank You: phasefreq
5 years 3 months ago #214377 by andypugh
I guess what set in my mind that DH params would be hard to deduce on my own is that my PUMA arm has mechanical mixing (wrong term?) in the wrist- moving either of the involved servos alone causes both a twist and a bend of varying rates; to move only one joint, both servos need to move synchronously at different rates.
I _think_ that this can be solved in HAL, external to the kinematics. I have looked at it in the past and decided that it would work, but didn't have long enough with the robot to get there.
5 years 3 months ago #214378 by andypugh
By which I mean use standard DH kins, then intercept the joint position commands before they go to the motors and mix them there before passing them on.
5 years 3 months ago #214610 by phasefreq
Replied by phasefreq on topic Motoman K6SB Retrofit
So the original drives for this arm, which I’m going to pick up from a kind enthusiast in Ohio, are SGDR-SDAxxxx; that model number isn’t listed on @dm17ry ‘s site as being mechatrolink compatible unfortunately, but I haven’t dug through (or found) the documentation to confirm.
I have an SGDH and an SGDV drive coming from eBay, both apparently mechatrolink ii and thus Dimitri-compatible. If I can convince them to operate the servos in my arm, I can eBay a few more of them- they are reasonably affordable. The Dimitry setup sure looks least complicated!
The servos in the arm, btw, are, from base to wrist:
- USAPEM-07YR21
- USAPEM-07YR13 (2x)
- USAREM-01YR41 (3x) (what’s the difference b/t USAPEM and USAREM?)
Anybody know anything about the proprietary absolute encoder interface?
5 years 3 months ago #214613 by phasefreq
This does sound like it’d work, good idea. I was actually able to get that arm (my smaller one with the mechanical mixing) to work using the linuxcnc-provided puma kinematics module after fooling with the nontrivial kinematics DH settings for a while. This arm, I am happy to learn, doesn’t actually use any mechanical mixing- looks like I should be able to deduce the encoder and gear drive ratios, measure the joint center to center distances best I can, and be in business.
5 years 3 months ago #214641 by dm17ry
Replied by dm17ry on topic Motoman K6SB Retrofit
0
no, they are not.
googling for SGDR and CN102 reveals some motoman manuals mentioning
CN102 as PWM amplifier control power
CN1 as PWM signal
so i guess SGDRs are "dumb" amplifiers with a current feedback only. encoders connect to a separate board, not to servopack.
USAREM are "Regular" series motors
USAPEM are "Pancake" style
no, i don't know what protocol encoders use
info.ammc.com/hubfs/Partner%20Documents/...20-%20150133-1CD.pdf
The following user(s) said Thank You: tommylight, phasefreq
Time to create page: 0.898 seconds
