Homemade, cheap, plasma CNC
5 years 3 months ago - 5 years 3 months ago #213755 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Rod's design is what I will be basing my new design around. I would love to buy one but can't stretch the budget that far. Rods unit is awesome ! very well built and robust.
I'l going to run a set of 12mm linear rails down the sides of my existing unit, then fold up a piece to joint then into the threaded rod. Then I'll run another 12mm linear rail to allow for the floating torch holdeBefore makeing a new mount for the plasma torch. Currently just using a hand torch until I can save up for the machine torch.
so i'l end up with this c-beam
www.makerstore.com.au/product/c-beam/
with these linear rails
www.makerstore.com.au/product/hard-mgn12/
and my existing motor and ball screw to hopefully give me 150mm of torch travel.
Last edit: 5 years 3 months ago by RNJFAB.
5 years 3 months ago #213756 by rodw
Replied by rodw on topic Homemade, cheap, plasma CNC
James in AU, just wait until James in NZ tidies my design up :) But please don't publish the model cos I might want to sell the plans one day...
A piece of 40x80x4 RHS from  Action Aluminium near my work is a lot cheaper (and lighter) than the extrusions. Then you can afford the HGR15 rail :)
How much do you value the convenience of extrusions?
My ballscrew is 150mm and gives me 86mm of travel which is enough.
The following user(s) said Thank You: RNJFAB
5 years 3 months ago #213757 by RNJFAB
Thanks Rod,
I do have to come up this week and grab some more ally for a few jobs so might add a bit extra on for the z axis. I was thinking of recycling what I already had, however it will probably be easier to copy Joco.
I have some 5mm plate lying around so may just start cutting tonight the bits that I can. Or I may just get it all drawn up so I’m right to cut once I have all the bits.
Cheers
5 years 3 months ago #215190 by RNJFAB
Hey all,
first problem I need help with,
I have tried to run some programs with the pierce only option so I can try and save some electrodes and nozzles.
I get the following error. I’m not sure if it’s a setting I need to fix in sheetcam or if it’s in Linux. any direction appreciated.
cheers
5 years 3 months ago #215195 by RNJFAB
Attachment not found
5 years 3 months ago #215210 by phillc54
In line 25 you possibly require a G0 at the start of the line.
Time to create page: 0.366 seconds
