Some Plasma Art
30 Oct 2021 22:51 #224736 by snowgoer540
Replied by snowgoer540 on topic Some Plasma Art
So I got the ini file all fixed up and the thc is working pretty good now. I tried tracking down that delay issue and.....
I am prettty sure it is in the pro-cut as I seen the QTP send torch on three times before the procut started the arc after a delay.
If you are seeing it send the torch start signal, but your procut is not responding, then it could be that you actually need a greater "Retry Delay" between trying torch-on commands for the procut to settle down. Also, 3 times is the default number of tries before it errors out and gives up. (sorry of you're already aware of that info)
31 Oct 2021 00:08 #224742 by rodw
Replied by rodw on topic Some Plasma Art
Also check you have good connections on the ground clamp on the plasma cutter to the material. The number of times this has caught me out is bloody annoying.. Last week I bolted the ground cable direct to the table AND added a cable for material clamp so hopefully If I forget the table will do it for me.
31 Oct 2021 07:55 #224753 by phillc54
Replied by phillc54 on topic Some Plasma Art
I keep meaning to do that as well, but I also keep forgetting.
31 Oct 2021 09:08 #224755 by Clive S
Replied by Clive S on topic Some Plasma Art
+ 1 (or is that 2)
31 Oct 2021 12:00 #224760 by snowgoer540
I did this quite some time ago, it’s definitely worth the extra effort :)
31 Oct 2021 12:59 #224766 by rodw
One can't rush into these things. I've had the parts for two years while I was preparing for the project!.
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
31 Oct 2021 15:10 #224771 by bevins
Replied by bevins on topic Some Plasma Art
Yeah I have the permanent ground connected. The machine is actually running great now.
31 Oct 2021 20:09 #224790 by snowgoer540
Happy to hear it!
Time to create page: 0.121 seconds
