Kinematic model for a 5axis mill with universal (nutating) head
3 years 5 months ago - 2 years 9 months ago #271334 by Aciera
3rd UPDATE :
The zip folder below now contains two configs:
1. Table rotary C - spindle rotary B - spindle rotating (nutating 0..90°) A
2. Table rotary B - spindle rotary C - spindle rotating (nutating 0..90°) A
The spindle setup is defined in a [TWP] section in the ini file.
I have expanded the original config and documentation to a generic configuration with variable nutation angles 0-90°.
Also the Tilted Work Plane (TWP) section in the documentation has been expanded.
Note that that the TWP remap is still fairly experimental!
File Name: table-rota...g.tar.gz
File Size:768 KB
ORIGINAL POST:
This is from work I've been doing to derive a kinematic model for a milling machine with a 45° nutating head like this one:
Notes:
1. TCP kinematic works
2. TOOL kinematics work also but there are some quirks that I have not been able to figure out. Like an odd behavior when issuing an incremental move immediately after switching to tool kinematics.
3. The attempted implementation of 'Tilted Work Plane' GCode is still rather experimental and would need a fair bit more work.
4. The config requires a custom vismach.py file for visualisation.
5. This kinematics requires version 2.10pre (ie master)
6. Documentation is included in the config folder as an html document.
File Name: spindle-ro...g.tar.gz
File Size:218 KB
Maybe somebody finds this useful
Last edit: 2 years 9 months ago by Aciera. Reason: 3rd update
The following user(s) said Thank You: andypugh, grandixximo, danilom, tommylight, tivoi, rodw, besriworld, cakeslob, AndrewL
3 years 4 months ago #274301 by grandixximo
This is coolest thing i've seen in a while, I'll have to study the configuration, congratulations man, looks amazing!
3 years 4 months ago #274307 by Aciera
3 years 4 months ago - 3 years 4 months ago #274308 by Aciera
Last edit: 3 years 4 months ago by Aciera.
The following user(s) said Thank You: besriworld, Gurpreet
2 years 11 months ago - 2 years 11 months ago #285796 by Gurpreet
Hi, I'm trying to understand the matrix math to create the kinematics for 50 degree nutating spindle. It's a XYZAC with spindle rotating and nutating, fixed table machine.
I'm following the manual found in the attachment. I'm stuck in the Inverse transformation section. Please see attached picture of the formula.
Could you please explain what that mean.
Last edit: 2 years 11 months ago by Gurpreet.
2 years 11 months ago #285798 by Aciera
That would be the transpose of the rotation matrix for the table rotary C.
Since you have a fixed table and an AC spindle rotary assembly you would omit the C table rotation in my writeup and replace the B spindle rotation with a C spindle rotation (ie you would have 'Rc' instead of 'Rb' on the spindle side).
Also there is a typo in my write up: both of the lower two formulas are for inverse transformation (P_A_Q) and not just the last one.
The following user(s) said Thank You: Gurpreet
Time to create page: 0.392 seconds
