Matrix Keyboard controlling LinuxCNC
3 years 1 month ago #280926 by AlexMagToast
i didn't know you are in China.
Do you manufacture these Keyboards?
I'll update you, if i tested the Code myself.
3 years 1 month ago #280929 by panming
I come from a manufacturer of CNC lathes in China, this is the panel is our supplier's product, because I think the price is low (about 600 yuan), so I want to try it.
For me, LinuxCNC is nothing short of torture, and it's good to have you kind people.
Thank you again
3 years 1 month ago #280931 by AlexMagToast
so i found a bug, that might have prevented it from working for you.
I also updated it to Github.
I've made it a 3x3 matrix and it works like this on my setup following the method above.
3 years 1 month ago #280933 by panming
I was able to light up the LED as directed!!When I use a matrix key and a matrix keyboard separately, they both work fine.
But When I use my panel ,there are two problems,
1.when I open the keypad macro program, the LED blinking frequency starts to decrease.
2.Because keypad and multipleds share the rows, when I set the pins of the row to be the same, both keypad and multipleds don't seem to work properly, when I type M1:1, the whole column is lit, and when I press the key, it seems to be arranged vertically.
I noticed that both macros use the same variable name, is this caused by this. Or my wiring problem.
In any case, we are one step closer to success.
3 years 1 month ago #280941 by AlexMagToast
Thanks for the Feedback. I changed the Code a bit, so now the Pullup resistors from the Matrix Keyboard are disabled, while the LEDs are flashed.
I guess that could help.
3 years 1 month ago #280946 by AlexMagToast
Btw it should also work in LinuxCNC now. which Linux is your system running on?
