I have already tried all the functions of this application. But with the latest version the Latching Potentiometers / Selector Switches are not working for me, they always appear at zero:
Type Dir Value Name
4 s32 OUT 0 arduino.LPoti.3.out
4 s32 OUT 0 arduino.LPoti.4.out
4 s32 OUT 0 arduino.LPoti.5.out
4 s32 OUT 0 arduino.LPoti.6.out
4 float OUT 497 arduino.ain.7
4 float OUT 437 arduino.ain.8
4 s32 OUT 0 arduino.counter.0
4 s32 OUT 0 arduino.counter.1
4 s32 OUT 0 arduino.counter.2
4 bit OUT TRUE arduino.din.29
4 bit OUT TRUE arduino.din.30
4 bit OUT TRUE arduino.din.31
4 bit OUT TRUE arduino.din.32
4 bit OUT TRUE arduino.din.33
4 bit OUT TRUE arduino.din.34
4 bit OUT TRUE arduino.din.35
4 bit OUT TRUE arduino.din.36
4 bit OUT TRUE arduino.din.43
4 bit OUT TRUE arduino.din.44
In the previous version they worked for me without problem.I also found that the Trigger INPUTS (SINPUTS) inputs always start in the on state (TRUE), I don't know if this is a problem, I think they should start in the off state (FALSE)I attach my ,ini and .py files to see if the problem is a bad configuration.
