That's kind of like saying "I'd rather buy a dump truck than a Ferrari", They're not really serving the same purpose.Seems quite expensive for what it is on my side of the world. I would rather buy an industrial wireless pendant/MPG for similar money.
My friend was maintaining the AUR package for LinuxCNC for a while because I was using LinuxCNC+Arch for something but that was 2.8 IIRC. Somebody else is maintaining it now @ 2.9 and it looks like it was updated about a month ago so assuming it works there shouldn't really be anything to it, Just install it via pacman or pamac. Arch always has RT kernels ready so It should be fairly easy. I generally just use Debian for machine stuff so I can't say I've used the 2.9 AUR packageArch Linux to be exact, and there once was a how to on installing LinuxCNC on Arch.
Add a USB-C to ETH adapter and oh joy ... leme try to convince my little brother that i need a SteamDeck for work !
Correct, it is just a small LCD behind the button grid, which is really a cost-effective and pretty clever way to do it. There are companies that make keys with displays in them, but the costs are pretty absurd. On the upside, you could locate the butons individually on a control panel rather than being limited to a single grid of buttons.That said the StreamDeck is a bit too expensive for what it actually is, those buttons aren't individual LCDs it's actually 1 common size LCD panel with clear windows as buttons. The buttons themselves are conductive rings pressing against a PCB or membrane. Kind of like if a Nintendo controller but with punched out rings as buttons. I don't know that there's anything special about that device itself other than some software. Like the button images are just icons on an LCD screen.
It's actually pretty solidly built, for a piece of consumer/semi-professional gear. The clear buttons feel more like polycarbonate than acrylic, which is good since acrylic tends to craze and crack when exposed to coolant.Besides being made of consumer grade plastic, the construction probably it would probably work out OK in a shop, the way the button layer is constructed it's probably fairly well sealed.
The implementation here is pretty cool, seems like a good idea. I don't know anything about StreamDeck software but I wonder how hard it would be just to implement something like this on a just a basic LCD with a custom button overlay panel....software wise
