Announcing Deckard: StreamDeck support for LinuxCNC
1 year 7 months ago #323129 by stefan63
Have you seen this?
I have tampered with it for a short period and it looks great.
I beleive it would be possible to use it as base and build a one or several LinuxCNC plugins for it!?
I use a 15 key streamdeck for tests and have had no problems to simply create keybord macros.
streamcontroller.github.io/docs/latest
1 year 3 months ago #331178 by Surmetall
Hello all,
i really like the idea of using a Streadeck for CNC-Machines. i think it opens endless possibilities and is quite handy
Thank you for your great work, I will try it as soon as possible!
I plan to use it on my cnc lathe.
Hardware of the Handwheel/Keyboard is ready now :)
forum.linuxcnc.org/26-turning/55587-wema...rcat?start=10#331177
greetings
Tom
The following user(s) said Thank You: RotarySMP, atrex77, Unlogic, GeckoWorks
1 year 2 months ago - 1 year 2 months ago #333091 by GeckoWorks
There are now a few cheaper clones/competitors out there, too. Generally called Streamdock (not deck) and it seems they come from another(?) OEM and are often sold under the Mirabox name but they are sometimes rebranded, too.
Prices are all over the place though as in my brief search, I have seen the 15 key version ranging from USD 50-100.
Not sure if the protocols are identical or it would take a lot of re-work to make them work with Lcnc.
But they are quite a lot cheaper so might lower the bar for people interested in getting into these.
Also, on at least one of the models, the buttons seem to be a bit larger than on the real Streamdeck - which might not be a bad thing for machining use.
Last edit: 1 year 2 months ago by GeckoWorks.
1 year 2 months ago #333293 by Beovoxo
1 year 2 months ago #333316 by RotarySMP
You did a nice design to integrate the streamdeck, and all the other controls into that interface unit.
9 months 3 weeks ago #341241 by Surmetall
Hello Steve, I just wanted to say Deckard is awesome. Really great work and thanks for sharing it to the world. The HAL-first approach is exactly what I was looking for.I’m currently installing it and starting to test it on a lathe, I see a lot of potential in it.Are you still actively working on Deckard, or planning to continue? I’m especially interested in multi-page / page switching, because that would be the killer feature for a Stream Deck in LinuxCNC. Being able to switch layouts automatically between Jog, MDI, Auto, tool offsets and touch-off and so on would make it unbeatable compared to fixed physical buttons.If you have any thoughts on where this is going, or a recommended workaround in the meantime, I’d love to hear it.
 greetings,
Tom
The following user(s) said Thank You: rmavalente
Time to create page: 0.280 seconds
