- Thank you received: 7
That will do 75mm of motion for a single rotation of the motor, and will have plenty of vibrations, but since you already have that set, do give it a try.The axes are driven by 3Nm Nema 23 stepper motors and an HTD-5M timing belt with a 15-tooth pulley, without any gear reduction.
For axample:
Aluminium extrusion profile L=1200mm (2.9 kg) vs aluminium 50x50x2 tube L=1200mm (3.6kg)
