Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
1 year 8 months ago #322211 by tommylight
Rotary machines for round tube are easy, just set them as normal 3 axis machine and make separate configs for each diameter, and use normal 2.5D CAM.
Square tubing is much harder to do properly.
And, i have built machine with attached rotary, almost always concluded that separate machines are better. You can not use both parts of the machine at the same time.
1 year 7 months ago #323895 by Daan96
Sorry for the late message. Unfortunately I had to give the project less priority.
At the moment very busy with my full time work, my own company and graduating from my bachelor mechanical engineering next to a more than full-time job.
I am slowly designing further on the mechanical part during my breaks. The hardware will be a pc that runs on plasmac in combination with a mesa board and a thcad.
The drive will be a belt, I do not believe that this stretch is noticeable under the load of plasma cutting. Much cheaper and simpler in design than rack and pinion.
1 year 7 months ago #323920 by timo
Replied by timo on topic Building a 4-axis plasma table
Last i checked, something that comes close to QtPlasmaC in functionality (not in usability by far, much harder to use) was over 170000$ with a 300A plasma source that costs 84000$, leaving the machine price at 86000$ for 6X2.5M cut envelope!
Are you saying that plasma table you checked was about a quarter million? USD? 170 000 + 80 000 ?
1 year 7 months ago #323923 by tommylight
No, total was 170000$, the price of the included XPR300 was 84000$.
1 year 7 months ago #323945 by rodw
Replied by rodw on topic Building a 4-axis plasma table
About 8-10 years ago we looked at an entry level hi definition plasma table and it was AUD $130k direct from the manufacturer.
The following user(s) said Thank You: Daan96
1 year 7 months ago #323952 by tommylight
To normal people, those numbers seem very far fetched as there is no pricing info for anything like that.
As Americans say: if you have to ask for the price, you can not afford it.
And when you do ask, be sitting with a glass of cold water in hand and 911 on speed dial.
Only when you have invoices in hand for such stuff, you start believing (coupled with the headache it induces) :)
See if you can find pricing for commercial license 5 axis CAM and report back here, if you can! :)
