New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
05 Oct 2026 16:42 #350129 by tommylight
It makes it possible to successfully retrofit older machines—such as complete Homag woodworking centers with multiple table zones—using LinuxCNC.
I am pretty sure that can be done already, see G55, G56, etc.
05 Oct 2026 18:30 #350139 by retrofitcenter
Servus, thanks for your message, nice to meet another Austrian here!
I’m originally from the Amstetten area, but Salzburg is also home for me. I went to HTL in Steyr, and I’ve been self-employed for around 20 years, mainly working in the aerospace and automotive industries.
My background is primarily in PLC programming, CNC machining and industrial automation. Over the years I’ve worked on pretty much everything around metalworking: mechanical engineering, machine automation, fixtures and clamping systems, CNC programming, commissioning, and of course complete machine retrofits.
I also started working with LinuxCNC very early on and was one of the first to use it seriously for machining centers rather than just simpler hobby machines. That experience is actually one of the reasons why I’m now pushing the multi-channel system further, I see a lot of potential for bringing older but mechanically excellent industrial machines back to life.
Your Homag example is interesting as well. Multi-channel control could definitely open up a lot of possibilities for machines with several working areas, tables or independently coordinated processes.
The following user(s) said Thank You: COFHAL, NWE
05 Oct 2026 19:00 #350141 by hermann1976
tommylight post=350129 Benutzer-ID=17274
hermann1976 post=350128 userid=26821
Es ermöglicht die erfolgreiche Nachrüstung älterer Maschinen —z. B. kompletter Homag-Holzbearbeitungszentren mit mehreren Tischzonen— unter Verwendung von LinuxCNC.
Ich bin mir ziemlich sicher, dass dies bereits möglich ist, siehe G55, G56 usw.
I am indeed referring to a multi-channel control system.
The machine works on a component on the left machining table, while the next part can be set up on the right table simultaneously. Once setup is complete, the program is started and the table moves to a standby position. Only when the left-hand part is finished does the machining head move to the right to execute that program. At the same time, the left table moves out of the machining area to a parking position for re-setup.
There are also multi-head systems, and so on.
The following user(s) said Thank You: NWE
05 Oct 2026 19:11 #350142 by Todd Zuercher
At one point in the past I was getting quotes for buying a double router like that. In the end our company decided it was more cost effective and practical to simply buy two separate machines.
The following user(s) said Thank You: tommylight, NWE
05 Oct 2026 21:19 #350143 by tommylight
I have to agree with Todd, such machine is much more versatile with two separate controls.
A nice local network with a NAS would also add a lot to functionality and ease of use.
11 Oct 2026 07:55 #350195 by Szumek
Hi, I have a Gildemeister GDM 42 retrofitted with LinuxCNC, featuring two turrets and a sub-spindle. I’m looking forward to a solution like yours and would be happy to test it out.
22 Oct 2026 01:09 #350388 by retrofitcenter
Hi all,
a quick update from the multichannel LinuxCNC project I posted about earlier (looking for testers with real machines). Everything now lives on our new site: www.cnc.gmbh
What you'll find there:
Try it online – a live test environment where you can run the multichannel system in your browser, load programs for several channels and see how the synchronisation (wait marks, channel coordination, Sinumerik-style syntax) behaves, no install needed.
Download - the current .deb packages for Debian [12/13] (amd64, [arm64]) plus the full source code. Build instructions are included.
Config generation offer, since the most common question is "how do I get my machine running with it", we're offering, for a limited time, to generate the complete LinuxCNC configuration (INI/HAL, channels, axes, spindles, I/O) for your retrofit, works for existing LinuxCNC setups you want to migrate as well as brand-new retrofits. Send us your machine data and drive/IO hardware via the form on the site, and you get a ready-to-run multichannel config.
Feedback, bug reports and especially reports from real machines are very welcome, either here in this thread or via the site.
Thanks,
Daniel
The following user(s) said Thank You: tommylight, yrsiddhapura, NWE
22 Oct 2026 14:22 #350400 by automata
I registered on the site for trying the community edition.
But could not download the deb or the src to be able to try anything.
Even the link to the manual gives a 404 error.
I would appreciate a heads-up on this thread once you get a chance to get the site working.
Thanks,
-automata
22 Oct 2026 15:28 #350406 by NWE
getting the same errors here
22 Oct 2026 16:20 #350409 by retrofitcenter
Hi automata, hi NWE,
thanks a lot for trying it out and for reporting this and sorry for the trouble. You're right: the download section and the manual link on cnc.gmbh are currently broken. The site was just migrated to a new system and the file links didn't make it over correctly.
I'm fixing it right now and will post here as soon as the .deb packages, the source code and the manual are downloadable. Your registration stays valid, so no need to sign up again.
Thanks for your patience and looking forward to your feedback once you have it running!
Daniel
Time to create page: 0.156 seconds
