- Thank you received: 37
tool length probe subroutine for Probe Basic
- TooTall18T
2 years 3 months ago #306110
by TooTall18T
Replied by TooTall18T on topic tool length probe subroutine for Probe Basic
Die Subroutine ist aktuell nur auf den Gebrauch mit Probe Basic (GUI) ausgelegt.
Da du Gmoccapy benutzt, müsste man ein wenig die Routine umschreiben, oder in Gmoccapy einen Tab erstellen, der die Aufgaben des Tabs aus Probe Basic übernimmt. Da ich Gmoccapy aber nicht kenne, weiß ich auch nicht wie einfach oder schwer das ist.
- TooTall18T
2 years 1 week ago #312667
by TooTall18T
With the release of Probe Basic 0.6.0 they changed their tool measurement routine and now they also use the .var-file to store the settings.
Unfortunately, this leads to overlaps and my routine (V4.0) is no longer compatible with version 0.6.0 of Probe Basic.
It will take some time until I get around to adapting and testing everything.
As soon as I'm done there will be a new version and I'll let you know.
- TooTall18T
1 year 10 months ago - 1 year 8 months ago #316423
by TooTall18T
I opened a develop-branch for a updated version of my subroutine.
Version 5.0.0 will be for Probe Basic 0.6.0 (and hobefully higher) and can also be used with every other GUI.
Using M600 Tx(tool change and measurement) and M601(only measurement) the subroutine can be controlled from any GUI.
You can find all files here:
github.com/TooTall18T/tool_length_probe/tree/develop
It is now a release version:
[url] github.com/TooTall18T/tool_length_probe/releases/tag/5.0.1 [/url]
Last edit: 1 year 8 months ago by TooTall18T.
- TooTall18T
1 year 8 months ago #320837
by TooTall18T
I made the 5.0.0 develop to the main branch and made a release for it.
The way the routine works is the same as you can see in the video of version 4. Also the way to install it is the same.
I was not able to make a version that is usable with all versions of Probe Basic. So I need to make a cut.
Version 4.0.1 is for Probe Basic up to 0.5.4-stable.
Version 5.0.0 is for Probe Basic 0.6.0 and it is also usable with every other GUI.
The following user(s) said Thank You: Muftijaja
- TooTall18T
1 year 8 months ago #322513
by TooTall18T
It all took a little longer, but I have a presentable development status for version 6.0.
In Probe Basic, the tool measurement routine can now be fully configured via its own user tab.
The page also contains a subpage with a little help on the settings.
The settings are no longer communicated via parameter file (.var), but via HAL pins. The parameter file now functions as a backup. Either because you want to test other values or as a security backup.
Using the installation script, the files and folders can be quickly edited and moved to their location. Of course, a backup of all files is created. In the test phase, however, it might not be a bad idea to back up the machine folder completely.
LinuxCNC min 2.9.3, Probe Basic min 0.6.0-37.dev and QTPYVCP min 5.0.2-5.dev are required.
Nothing has actually changed in the routine's processes and no new functions have been added yet. Nevertheless, the routine for the connection to the GUI has been revised.
What has changed, is the way in which the offset is created for tools with a large diameter. An offset is no longer created across the board from a certain diameter, but a value is entered in percent in the "FNT ANGLE" column in the tool table. This means that each tool can be offset individually.
You can find everything here: [url] github.com/TooTall18T/tool_length_probe/tree/develop [/url]
The routine itself can also be used without Probe Basic (user tab). Information about this can be found in the manual.
The following user(s) said Thank You: tommylight, Haarie, Muftijaja
- Edi_48
1 year 1 week ago - 1 year 1 week ago #336738
by Edi_48
Replied by Edi_48 on topic tool length probe subroutine for Probe Basic
Hallo ich habe deine Installation gemacht,
Fahren auf Referenfpunkt geht
Fahren auf G30 ist Ok
Werkzeug wechsel geht nicht Fehler :Kein Werkzeug in Carosell
In der ini habe ich bei ATC_TAB_DISPLAY= 0 , Atc Pockets=0
Frage wo ist der Fehler
Last edit: 1 year 1 week ago by Edi_48.
Time to create page: 0.310 seconds
