retrofit Bridgeport Prototrak Plus
26 Jun 2016 12:18 #76674
by new2linux
Replied by new2linux on topic retrofit Bridgeport Prototrak Plus
If the work around for the proprietary control cards are the Mesa product line, what is the work around for power supply or more specifically power supply amplifier. I can appreciate it has to mate up with the specific drives. I have also seen complete televisions laid out (this was a vo-tech demonstration some years ago) so no PSB and it worked. I see that there is cooling and other requirements that may extend life of the components, and see a lot of components, what type of things don't I have an appreciation for?
many thanks
many thanks
27 Jun 2016 02:04 #76689
Is your meter on an AC range?
Replied by andypugh on topic retrofit Bridgeport Prototrak Plus
It needs time to charge up, but only goes 0.5 v on 0 to 26; and only 1.5 v 0 to 52. .
27 Jun 2016 11:06 #76701
by new2linux
Andy, I am truly grateful for your help. The meter reads 2.5 v on 0 to 26; and 5.5 v 0 to 52, and steady.
many thanks
many thanks
- Thank you received: 1369
27 Jun 2016 13:16 - 27 Jun 2016 13:17 #76707
Replied by Todd Zuercher on topic retrofit Bridgeport Prototrak Plus
What is the voltage input to the transformer?
Are you sure you have the settings right and reading the that old analog meter correctly?
forum.linuxcnc.org/media/kunena/attachme...21712/IMG_0817_1.JPG
Last edit: 27 Jun 2016 13:17 by Todd Zuercher.
27 Jun 2016 17:42 - 27 Jun 2016 21:13 #76721
by new2linux
With the"polarity"(knob to the left) setting in AC, and the scale setting (knob to right) set to 600v, read scale that is red (kind of in the middle, AC on each end) when reading input on pins 0, & 115; the needle shows 110 volts, about 1/6 of scale. If I have not read this correctly please speak up.
many thanks!
Edit: New Lavolta BPS305 Variable Linear DC Power Supply due in.
many thanks!
Last edit: 27 Jun 2016 21:13 by new2linux. Reason: power supply due
30 Jun 2016 18:44 #76864
by new2linux
Power supply has arrived, as per user manual, "MINVOLTS" as well as "MAXVOLTS" as well as "MAXAMPS" are parameters that need to be set prior to the testing of the system. Can someone help with the setup?
many thanks
many thanks
30 Jun 2016 19:08 #76866
I would have the min volts at 0, max volts at 5 and current at 10mA to start with. If the output voltage is less than 5V at that current then try increasing the current. I would probably start to get a bit concerned above 0,1A, and start feeling for hot components.
01 Jul 2016 10:48 #76885
by new2linux
Andy, to review how this is set up, to insure its correct. The power supply when set to 5 voltage at 0.1 current (when + and - are connected together the cc light or the cv will be lite), with (5 v) power supply on, with 110 volt power supply on and with the 5 volt going to the pins from power amplifier (that are going to the 7i77 card) with linuxcnc up running. The front of the 5 v p/s has 5.0 v and green cv light on, the current says nothing, should I increase this with the fine setting.
01 Jul 2016 12:20 #76886
No! Do _not_ connect the 110V.
This test is to check the condition of the Low Voltage DC circuits.
01 Jul 2016 12:52 #76888
by new2linux
Andy, what I described is what happen, the meter on 5 v p/s was as stated. I did not see any issues, but no motion in drives, the drives when rotated by hand show as motion on the screen. What should I be looking for?
many thanks
many thanks
Moderators: piasdom
Time to create page: 0.160 seconds
