esab ultrarex retro fit plasma / flame cutter
24 May 2012 11:18 #20322 by jd896
no this was in axis i had been using version 2.4.3 i thought it was the new one the new one was on a different usb stick i have upgraded now but in pncconf i cannot do any open loop tests
will keep digging
24 May 2012 11:28 #20323 by BigJohnT
jd896 wrote:
can't read "ininamearray(0)": no such variable
this is the error i get when trying to calibrate also the boxes in the calibration window are blank/missing i.e. no hal values and names and such
as i said the first config was produced with pncconf am i better posting this problem the that section of the forum ?
thanks guys getting there slowly
Starting a new thread in the Pncconf section would get the attention of the author of pncconf.
24 May 2012 12:28 #20324 by cncbasher
can you post your ini and hal file , and i'll take a look
24 May 2012 12:57 #20326 by jd896
hi cnc basher as i said i have now upgraded to the current version but am now unable to even run an open loop servo test on the pncconf window but also i dont think the firmware its picking up is correct how would i know what is is i still have the ini and hal files from th previous version for reference
thanks
24 May 2012 13:29 - 24 May 2012 13:32 #20327 by cncbasher
have you the correct folder for the ini and hal files etc , in the older version it is EMC2 the newer version is LINUXCNC
along with the approprate changes to the paths etc in the ini
which mesa card are you using ?
and which bit file ? also check that the bit file exists
Last edit: 24 May 2012 13:32 by cncbasher.
24 May 2012 13:37 - 24 May 2012 13:38 #20328 by jd896
i have to correct folder yes but the problem was when trying to make a new config completely with the pncconf i get to open loop test's and the button is grayed out
im also not entirely sure which firmware to use i have a 5i20 7i33 7i37
Last edit: 24 May 2012 13:38 by jd896. Reason: missed some off
24 May 2012 13:40 - 24 May 2012 13:52 #20329 by jd896
since upgrading emc to the new version the firmware that pncconf picks up for the card is different from what is was from the previous version and i cannot do any open loop servo tests in pnc and therefor carnt finish the config or even look at whats wrong
question is where is the firmware stored on the card or is it passed to the card during cnc startup ?
also the files from the old build that have the axis calibration window issuei have found a thred regarding spaces in the pid lines for the hal file but i see nothing wrong when ever i edit it i get start up errors
File Name: my_EMC_mac...ae97.hal
File Size:6 KB
Last edit: 24 May 2012 13:52 by jd896.
24 May 2012 13:51 #20330 by andypugh
It is passed to the card during startup from the lib/firmware/hm2/5i20 folder.
If you have installed from scratch it is possible that you no longer have that folder.
sudo apt-get install hostmot2-firmware-all
might be required to get the latest set.
24 May 2012 13:53 - 24 May 2012 13:56 #20331 by cncbasher
the firmware is uploaded on startup , it should be located at \libfirmware\hm2\5i20
and select an approprate bit file SV ( SERVO ) xx if this is a servo machine
svst8_4.bit is current so it should be available
Last edit: 24 May 2012 13:56 by cncbasher.
24 May 2012 13:57 #20332 by jd896
i have tried that andy but it was up too date but i have noticed the firmware i used last time is there bit file and xml but they are not in the pnc window as a choice
Moderators: cncbasher
