esab ultrarex retro fit plasma / flame cutter
30 May 2012 17:39 #20513 by BigJohnT
From memory I added P in small steps till the axis starts to become unstable then a tiny bit if I then repeat until the following error is small enough. Watch the following error with each change to see if your improved it or made it worse. I also added one of the FF's but forget which one... oh here it is.
# PID tuning params
DEADBAND =              0.000015
P =                     40
I =                     2
D =                     0.01
FF0 =                   0.01
FF1 =                   0.26
FF2 =			              0.0005
BIAS =                  0.000
Turns out I used a tiny bit of everything.
31 May 2012 06:27 #20522 by jd896
See this is what throws me every body else's parameters are like yours 40-60 on the p and such does it depend on the axis scaling ie encoder counts to axis movement as I cannot get my p above say 1 stably ATM it's around 0.9 with more d than I and I think there is still a bit much p as the scope is still quite course
Thanks for all your help john
31 May 2012 11:05 #20525 by jd896
afternoon lads just one quick question about this scope calibration method what kid of speeds do we want too be running at to tune the axis?
thanks
31 May 2012 11:27 - 31 May 2012 14:05 #20526 by PCW
PID parameters do depend on scaling but this can be factored out if desired by making the PID input and output commensurate. Since the input to the PID loop is in machine units and velocities are in machine units per second, for velocity mode servos, making th e DAC scale or output scale equal to machine units per second will make the units commensurate (this has the side benefit of making the FF1 term known = ~1 for velocity mode drives)
My guess as to why you have such small P term is that you have mm machine units so the input to the PID loop is larger than a inch machine (and the PID output units are probably somthing that has not be scaled to mm/sec
like 10V)
Last edit: 31 May 2012 14:05 by PCW. Reason: ommision
31 May 2012 11:51 #20528 by BigJohnT
thanks
Couple of things to consider, cutting speeds and rapid speeds. At cutting speeds you want a tight axis with little following error, at rapid speeds you can have a bit more following error as your not making a part but just getting there. You don't want an overshoot on a deceleration from a rapid or you might ram into a part. So you have to sort out what is acceptable to you for your machine. A plasma might sacrifice some accuracy for acceleration to maintain cutting speeds for artsy fartsy stuff with lots of direction changes.
So run the speeds your interested in obtaining and tune to that.
31 May 2012 15:29 #20530 by jd896
like 10V)
could you give this in more detail if possible is there a way to scale the out put also the dacs and scal are limited to 8 as this is the drives max input voltage
thanks pcw i thought it was just me doing something wrong not being able to get much p or ff1
31 May 2012 15:35 #20531 by andypugh
P is right when it is right, there is no absolute numerical target.
I have controller between millibar of oil pressure and valve duty cycle, that has a _tiny_ P term, about 0.002
31 May 2012 15:38 - 31 May 2012 15:50 #20532 by PCW
FF2 will tune out a spike during acceleration
also FF1 will tune out the constant negative following error during cruise
but something is funny here (like a lot of friction or way too low gain)
Notice that during the acceleration phase, the encoder doesn't even register any motion until
acceleration is almost done (end of the commanded velocity ramp-up).
Is this a velocity mode drive?
And like Andy says P is right when its right
Getting the input and output PID scaling right just makes the
numbers look more "normal" it will not affect the performance
Last edit: 31 May 2012 15:50 by PCW.
31 May 2012 21:45 #20541 by jd896
thanks PCW ive got the following error down within the 0.0x range now and considering this is mm not inches that not quite good for a plasma at 8ish m/m
also the drive for my y axis came back earlier on today so ive been getting that tuned got down to 0.2 till the morning
31 May 2012 22:43 #20542 by jd896
would this suffice for a torch control / start plasma routine
o<startcut> sub
M64 P0 (turn on cap height control - D out 1)
G4 P3.1 (pause for height control)
M64 P2 (start plasma - D out 3)
M66 P5 L0 (wait for plasma arc ok - D in 1)
o<startcut> endsub
m2
also the one for end of cut
o<endcut>
M65 P0 (turn cap height off - D out 1)
M64 P1 (raise torch to clearance - D out 2)
G4 P3 (pause for torch movement)
M65 P1 (stop torch up movement)
o<endcut>
m2
also are the M2 commands needed in the o word files ? i presume there to end the o word and continue with the program
Moderators: cncbasher
Time to create page: 0.144 seconds
