Error,
23 Dec 2016 16:15 #84625
by tjamscad
This should help with what I can't describe.
drive.google.com/file/d/1X3XSeql0a9D60dk...DrQ/view?usp=sharing
23 Dec 2016 16:22 #84626
by tjamscad
This appears to be what is happening when I turn the machine on.
Replied by tjamscad on topic LinuxCNC error on Enshu VMC530
This will allow LinuxCNC to load but when the machine is powered on the drives and contactors go crazy. The also causes a joint 2 following error. That is my Z axis.
- Thank you received: 5932
23 Dec 2016 16:22 #84627
Replied by tommylight on topic Error,
If you have schematics, you should really check for voltage drop on the 24V rail, and the mains power drop.
Also check for anything shorted on the 24V side. Start disconnecting things and testing, one by one.
That is a no god state as that switching on and off will mess up something else.
23 Dec 2016 17:34 #84633
by tjamscad
I dont know when these were done or how acuret they are but here they are.
drive.google.com/file/d/0B86EwtSOzbrjNHN...NkE/view?usp=sharing
23 Dec 2016 17:57 #84637
In your video one of the contactors is sparking a lot, so check what it is connected to or disconnect the output wires from it.
That might be the actual problem, but it also might not be, the sparking can be caused by an iductive load also.
23 Dec 2016 20:37 #84649
by tjamscad
If i comment out the XX axis PRDY line for X,Y and Z linuxCNC will boot and run I just can't move any axes.
# MACHINE ON
# connections to start machine when MACHINE ON is pressed
net MachineIsOn <= motion.motion-enabled
net MachineIsOn => ppmc.0.dout.00.out # X ax is drive enable
net MachineIsOn => ppmc.0.dout.01.out # X axis PRDY
net MachineIsOn => ppmc.0.dout.02.out # Y axis drive enable
net MachineIsOn => ppmc.0.dout.03.out # Y axis PRDY
net MachineIsOn => ppmc.0.dout.04.out # Z axis drive enable
net MachineIsOn => ppmc.0.dout.05.out # Z axis PRDY
net MachineIsOn => ppmc.0.dout.06.out # ESTOP
net MachineIsOn => ppmc.0.dout.10.out # hyd pump & spdl oil cooler
The relay that is sparking so much in the video is for the hydraulic pump.
# MACHINE ON
27 Dec 2016 04:50 #84733
by jmelson
Unfortunately, you are using non-standard board addresses, so the diagnostic program won't work properly.
The diagnostic is dumb, it will only test an encoder board at address 0, a DAC board at address 4 and a DIO board at address 6. So, if you change one of your encoder boards at a time to address 0, then you can test it with the commtest mode. Then, you can swap the address settings and try the other board.
If the commtest works OK, that will indicate that communication between the PC and the encoder boards is good.
If the commtest does not give a no errors report, then you have to debug further.
Jon
Jon
Time to create page: 0.103 seconds
