Error,
- cncnoob1979
- Thank you received: 75
13 Dec 2016 22:34 #84061
by cncnoob1979
Replied by cncnoob1979 on topic Error,
Use the command:
sudo
Prior to that command. Sorry forgot to put that in there.
sudo
The following user(s) said Thank You: tjamscad
- cncnoob1979
13 Dec 2016 22:45 #84063
by cncnoob1979
Post your entire configuration directory as an attachment here on the forum.
Type:
Sudo dmesg -c
prior to running linuxcnc and copying your error file from dmesg -c.
It clears your dmesg log so we can just see the errors related to linuxcnc.
Also post your dmesg.
Linuxcnc error log as well too please. We can get this going for you again or at least point to your problem.
Are you in the USA? If so contact me via email in my profile and we can chat on the phone when we get time.
Type:
Sudo dmesg -c
13 Dec 2016 23:24 #84066
by tjamscad
Here is what I get from dmesg. I will have to provide a drive link for the config directory. drive.google.com/open?id=0B86EwtSOzbrjVENZMkdNMlJvZWc
14 Dec 2016 14:23 #84091
Since the PPMC issue started when you changed the PC, it suggests that there may be something
wrong with the new PCs parallel port (either LPT mode, address, hardware/cable issues etc)
You may need to get Pico Systems/Jon Elsons help here. I suspect he has some LPT diagnostics
that can help narrow this down
14 Dec 2016 14:48 - 14 Dec 2016 15:07 #84093
by tjamscad
Last edit: 14 Dec 2016 15:07 by tjamscad.
Time to create page: 0.199 seconds
