Biesse Rover 346 Retrofit
20 Jan 2017 21:53 - 20 Jan 2017 21:57 #86299
Replied by PCW on topic Biesse Rover 346 Retrofit
I doubt anything has changed in the driver between 2.7 and 2.8
It may be more likely that there's a bug with the use_serial_numbers option
and more than 1 sserial port since this is uncommon setup (more than 8 channels total)
You might also try only enabling the sserial channels that you actually have connected
probably something like sserial_port_0=00x sserial_port_1=00xxxxxx
Last edit: 20 Jan 2017 21:57 by PCW.
- Thank you received: 5927
20 Jan 2017 22:08 #86301
Replied by tommylight on topic Biesse Rover 346 Retrofit
Just a remark, in your pictures i can see 7i77 and 7i70 are working properly but 7i74 has no green light on, i am sure on mine it is on full when active.
But 7i70 works through it, so..........
20 Jan 2017 22:48 #86305
by bevins
Yeah, I dont know why the green lite is not on on the 7i74,
Both are flashing on the 7i70 and 7i71 and 7i77 and I have all my pins.
I have seen the green lite on it though, but dont remember in what condition...lol
Replied by bevins on topic Biesse Rover 346 Retrofit
20 Jan 2017 22:50 #86306
by bevins
I tried disabling port 1 of the 5i25, and dropped port0 to just the channels used and still the same thing.
I'll see if there is an updated beta version.
20 Jan 2017 22:51 #86307
Shouldn't be, I don't think anything has changed there.
Can I repeat my question, and hope for a different answer? Your error is with loadrt hm2_pci, the loadrt hostmot2 use_serial_numbers seems to have worked.
Replied by andypugh on topic Biesse Rover 346 Retrofit
I am on 2.8 pre. IS it broken in 2.8 pre?
20 Jan 2017 22:57 - 20 Jan 2017 22:57 #86308
by bevins
Sorry if I missed your question.
That is correct, with hostmot2 use_serial_numbers=1 loaded it dumps with the hm2_pci line.
loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx sserial_port_1=00000000"
I tried with just one port and it failed with invalid parameters also.
Last edit: 20 Jan 2017 22:57 by bevins.
20 Jan 2017 23:05 #86309
Could be, I am pretty sure I didn't test that.
The simple answer for bevins is to just stop trying to use that option.
The more complicated answer for me is to try to fix that,
I think I would need a 5i24 config with a split 7i44 port to test with. But I guess that PCW is best placed to check if this is a real bug before making me a bitfile to fix it with.
20 Jan 2017 23:14 #86312
I can not insist on it as i use diferent firmware, but i am sure mine has green and orange as soon as LCnC starts.
You should check that the d25 connectors are seated properly just in case.
20 Jan 2017 23:14 #86313
by bevins
Gotcha... Thanks....
20 Jan 2017 23:20 - 20 Jan 2017 23:23 #86314
The green light on a 7I74 is the serial channel 7 drive enable state
It will not be illuminated on a sserial config unless a remote device is found
on that channel (channel 7)
This is a consequence of the fact that sserial pins revert to GPIO
if a sserial device is not found (and the default state is driver disabled for RS-485 compatibility)
Last edit: 20 Jan 2017 23:23 by PCW.
Time to create page: 0.323 seconds
