Biesse Rover 346 Retrofit
20 Jan 2017 23:34 #86315
by bevins
Andy, I can give you access to my machine if you want if that helps.
Replied by bevins on topic Biesse Rover 346 Retrofit
I doubt anything has changed in the driver between 2.7 and 2.8
It may be more likely that there's a bug with the use_serial_numbers option
Could be, I am pretty sure I didn't test that.
The simple answer for bevins is to just stop trying to use that option.
The more complicated answer for me is to try to fix that,
I think I would need a 5i24 config with a split 7i44 port to test with. But I guess that PCW is best placed to check if this is a real bug before making me a bitfile to fix it with.
- Thank you received: 5928
20 Jan 2017 23:35 #86316
Replied by tommylight on topic Biesse Rover 346 Retrofit
Oh that is why i get the green light!
I have 7i71 on that port 7.
Thanks for the info.
20 Jan 2017 23:41 #86317
by bevins
How many ports are you using on the 7i74?
21 Jan 2017 00:09 #86319
4 for SSI encoers ( i actually need 5, but i will replace the spindle encoder for an incremental one) and 2 SSerial for 7i70 and 7i71.
I can also do without 7i70 and 7i71 as there are enough inputs on the 7i77 but i am not sure how many outputs i will need, i am sure 16 is not enough as i would like to add some more signaling to the machine. And they make for a cleaner installation as the machine has all inputs in two cables and same for the outputs.....it is like tailor made for it, one cable per terminal block.
21 Jan 2017 00:25 - 21 Jan 2017 00:45 #86322
Replied by PCW on topic Biesse Rover 346 Retrofit
tommylight: its entirely possible to make a 5 SSI / 3 sserial config if you wanted to retain the absolute encoder on the spindle
bevens: I cannot duplicate the bug with use_serial_numbers.
Here (attachment) is a pin list from a system with use_serial_numbers=1 and 2 sserial devices
on port 0 (7I76 and 7I90) and 2 sserial devices on port 1 (7I87 and 7I73)
EDIT: I have included a normal (-nosn) pin list for comparison
Last edit: 21 Jan 2017 00:45 by PCW.
21 Jan 2017 00:27 #86324
by bevins
AH!!
I am going to have a 7i70, 2-7i71 and a 7i84, plus a 7i77. I wont run out of I/O anytime soon. I will have 116 relays on this machine.
AH!!
21 Jan 2017 00:40 #86325
Thank you very much Peter, but you have done more than enough, i just do not want to bother you anymore.
P.S. If by any chance you get the sudden urge to make such a config, 6 SSI 2 SSerial would be nice. And a 2 meter tall blonde to go, please, thank you very much.
P.S. of the P.S
Tall blonde added to keep the ball rolling on the wishes.
P.S. of the P.S
21 Jan 2017 00:53 #86326
Its really only a couple minute job to make a new config, but its dinner time here after a tough week
so I'm going to relax till Monday
21 Jan 2017 01:03 #86327
Enjoy it P.Its really only a couple minute job to make a new config, but its dinner time here after a tough week
21 Jan 2017 01:15 - 21 Jan 2017 01:15 #86328
by bevins
Tommy, you running 2.8 pre?
Last edit: 21 Jan 2017 01:15 by bevins.
Time to create page: 0.850 seconds
