- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
- tecno
- Thank you received: 127
29 Aug 2017 12:55 #98143
by tecno
Only adjusting numbers in DISPLAY makes a difference, but I can not wrap my head around the numbers.
If I set MAX_LINEAR_VELOCITY to 15 I get 900mm in GUI as max, so what is it that makes this so odd?
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
I _think_ that DEFAULT_LINEAR_VELOCITY is what you get with an unshifted arrow and the jog-speed slider at 100%
(And, yes, I think that shifted-arrow will use the 85mm/sec.)
It should be a fairly easy test to check it against the DRO numbers.
- Thank you received: 4645
29 Aug 2017 12:57 #98145
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
15 mm/sec = 900 mm/min
- tecno
29 Aug 2017 13:01 #98146
by tecno
Doh....
- Thank you received: 1466
29 Aug 2017 13:03 #98147
Replied by Todd Zuercher on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Do you want one button to toggle the coolant on/off, or one button for on and another for off?
The two button solution is simple and you just connect the button input pins to the appropriate Halui pins.
The single button approach requires some hal logic.
forum.linuxcnc.org/forum/47-hal-examples...lood-with-one-button
- tecno
29 Aug 2017 13:16 #98148
by tecno
Coolant
1 on/off switch on frontpanel to switch on coolant manually if need be to clean work piece but still use M8 as usual.
Oiler
1 push button to start oiler manually on frontpanel by holding button down = input on 7i73 to go to output on 7i76e but I
also want to have M7 to work temporarily until proper M code is in place for the oiler.
Oiler
29 Aug 2017 14:17 #98150
Why not just set it up as you want it from the start? Personal I'd prefer a more fully automatic arrangement for the machine lube system, and in Linuxcnc it isn't much more complex and requires no more hardware. (less in fact because you won't need the button.)
- tecno
29 Aug 2017 14:23 #98151
by tecno
I buy that as regards the oiler but prefer to have manual Coolant switch for cleanup jobs and not having to fiddle with the tackball to activate coolant pump.
29 Aug 2017 15:18 #98152
I put in three-position switches on my Lathe. Off-Auto-On. "Auto" means "G-code control"
The HAL logic is probably a mux_generic, but I might have used a LUT5.
- tecno
29 Aug 2017 15:38 #98153
by tecno
Is this valid and functional?
loadrt xor2 count=1
addf xor2 servo-thread
net cool1 xor2.0.in0 <= iocontrol.0.coolant-flood
net cool2 xor2.0.in1 <= hm2_7i76e.0.7i73.0.1.input-19
net both-on hm2_7i76e.0.7i76.0.0.output-04 <= xor2.0.out
loadrt xor2 count=1
29 Aug 2017 16:11 - 29 Aug 2017 16:13 #98154
Valid? Probably. Functional? Not likely.
If your button is a toggle on button (one press turns on, another press turns off) it will turn the flood on and off, but it will reverse the function of M8/M9, when it is turned on.
If the button is an ordinary momentary switch, then it will only do anything while you hold it.
The link I posted to before has every thing you need to set up single button override control of flood (mist would be simular).
Pressing the button when the coolant is off will turn it on, pressing it when it is on will turn it off, and the M8/M9 will still function as normal.
loadrt toggle2nist count=1
loadrt toggle count=1
loadrt and2.0 count=1
addf toggle2nist.0 servo-thread
addf toggle.0 servo-thread
addf and2 servo-thread
net coolant-flood <= iocontrol.0.coolant-flood => hm2_7i76e.0.7i76.0.0.output-04
# Flood Coolant Toggle
net coolant-btn <= hm2_7i76e.0.7i73.0.1.input-19 => and2.0.in0
net coolant-ok <= halui.machine.is-on => and2.0.in1
net coolant-request <= and2.0.out => toggle.0.in
net coolant-toggle <= toggle.0.out => toggle2nist.0.in
net coolant-is-on <= halui.flood.is-on => toggle2nist.0.is-on
net coolant-on <= toggle2nist.0.on => halui.flood.on
net coolant-off <= toggle2nist.0.off => halui.flood.offPressing the button when the coolant is off will turn it on, pressing it when it is on will turn it off, and the M8/M9 will still function as normal.
Last edit: 29 Aug 2017 16:13 by Todd Zuercher.
- PnCConf Wizard
Time to create page: 0.294 seconds
