Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
- Thank you received: 1369
30 Aug 2017 15:09 #98222
Replied by Todd Zuercher on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
The included sim Gmoccapy configs, include an example setting up a GladeVCP pannel with an RPM meter that interfaces with a simulated encoder. Use that example to make a pannel that interfaces with your spindle's encoder.
01 Sep 2017 12:45 #98330
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Just tested G33.1 = No Go
So I assume that something is missing in my settings, controlled earlier that Index was working so what can it be then?
Stops on this line G33.1 Z-20 K2 and Z axis is not moving.
01 Sep 2017 13:05 #98334
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Try changing the sign of the spindle-encoder scale. (I don't actually know which way it is meant to count for a milling machine)
01 Sep 2017 13:10 #98335
by tecno
# Spindle
[SPINDLE_9]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
ENCODER_SCALE = -4000.0
That is the setting now, negative due to encoder is rotating in reverse compared to spindle ( 1:1 gear shaft )
Will try shortly
# Spindle
[SPINDLE_9]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
Will try shortly
01 Sep 2017 13:41 #98338
by tecno
NoGo
01 Sep 2017 13:53 #98339
It should only need motion.spindle-revs and motion.spindle-enable to be connected.
Do you see motion.spindle-revs increasing by 1 every turn of the spindle in M3 mode and decreasing by 1 in M4 mode?
Does motion.spindle-index-enable go true and then false?
01 Sep 2017 15:29 #98341
by tecno
motion.spindle-revs = nothing
motion.spindle-index-enable true stays true and does not go false
This is the 5V encoder that is OK and checked with oscilloscope.
01 Sep 2017 15:33 #98342
Have you ever had any encoder working?
01 Sep 2017 15:39 #98344
by tecno
The one I have in my milling machine now has been working on my lab desk and verified with oscilloscope.
One of my 7i76e has input pins 13/14 = Index pins busted = not working. This is the one for my lathe.
The one in my milling machine is OK, shorting pin 13 and it works, but not now so I just wonder what is going on here.
Earlier tests was OK with setting spindle-index-enable true and rotating spindle it did goe false.
02 Sep 2017 06:44 - 02 Sep 2017 08:25 #98365
by tecno
I did go back to basics and teared down the encoder from my Lathe = 5V Omron E6C2-CWZ6C and verified it is working OK.
Done following tests, board #1 is the one for Lathe and has been here in my lab only and board #2 is the one in my milling machine.
New simple pncconf just for this test. num_encoders=1
Board 7i76e #1 with encoder in normal pins on 7i76e = NOTHING, connected 7i85S and moved connector to 1:st encoder = ALL OK
Board 7i76e #2 with encoder in normal pins on 7i76e = NOTHING, connected 7i85S and moved connector to 1:st encoder = ALL OK
So it seems that the faulty encoder has damaged both 7i76e spindle encoder inputs.
As regards board #1 this is for the Lathe looks like encoders can be managed via 7i85S as I only need 3 inputs.
As regards board #2 for the milling machine I need 5 encoder inputs = X/Y/Z/A and Spindle.
So my question is can the spindle encoder be connected to other inputs so I can get this machine ready?
Repair option, maybe Peter can chime in here and advise what part/parts to be exchanged (not afraid to do some SMD soldering).
Not so happy camper now, a bit unbelievable that this is happening with one faulty encoder.
/edit
As my A-axis is a bit far away then I can manage to get me going by setting num_encoders=4 I suppose.
Cheers
Bengt
/edit
Cheers
Bengt
Last edit: 02 Sep 2017 08:25 by tecno. Reason: Added text
Time to create page: 0.145 seconds
