Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
27 Jul 2017 17:15 #96580
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
To go back to an earlier question, you set the mode of the 7i73 with a string "sserial_port_0=" in the "config=" of the "loadrt hm2_eth" command.
If the 7i73 creates pins called "hm2_5i25.0.7i73.0.2.... then that means that the 7i73 is device 2 of port 0, and to set it to mode1:
loadrt hm2_etch board_ip=10.10.10.10 config=" .... sserial_port_0=00100000 ... "
The following user(s) said Thank You: tecno
27 Jul 2017 17:30 #96582
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
loadrt hm2_eth board_ip="10.10.10.10" config="firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=21xxxx"
I see it now when one learns where to look
27 Jul 2017 17:46 #96585
Replied by PCW on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
If you are running version 16 firmware CR1 indicates a watchdog timeout = latency issue
If you are not running version16 firmware, CR1 is not meaningful unless CR1 and CR2 are both on
(in which case you could not communicate with the card)
To determine the firmware version, you can run mesaflash
mesaflash --device 7i76e --addr 10.10.10.10 --verbose
How are you checking the output?
Note that the field I/O section is completely isolated from the logic section so you
must measure outputs relative to the field common connection
27 Jul 2017 17:56 - 27 Jul 2017 18:31 #96586
by tecno
Mesaflash does not exist !
Managed to get out on the web and got install done.
bengt@combimill:~$ mesaflash --device 7i76e --addr 10.10.10.10 --verbose
ETH device 7I76E-16 at ip=10.10.10.10
Communication:
transport layer: ethernet IPv4 UDP
ip address: 10.10.10.10
mac address: 00:60:1B:10:41:2B
protocol: LBP16 version 3
Board info:
Flash size: 16Mb (id: 0x14)
Connectors count: 3
Pins per connector: 17
Connectors names: on-card P1 P2
FPGA type: 6slx16ftg256
Number of leds: 4
Board firmware info:
memory spaces:
0: HostMot2 (registers, RW, 32-bit) [size=64K]
1: KSZ8851 (registers, RW, 16-bit)
2: EtherEEP (EEPROM, RW, 16-bit) , page size: 1, erase size: 1
3: FPGAFlsh (flash, RW, 32-bit) [size=16M], page size: 256, erase size: 65536
4: Timers (memory, RW, 16-bit)
6: LBP16RW (memory, RW, 16-bit)
7: LBP16RO (memory, RO, 16-bit)
[space 0] HostMot2
[space 2] Ethernet eeprom:
board name: 7I76E-16
user leds: eth debug
[space 3] FPGA flash eeprom:
flash size: 16Mb (id: 0x14)
[space 4] timers:
uSTimeStampReg: 0x7BF8
WaituSReg: 0x0000
HM2Timeout: 0x0000
[space 6] LBP16 control/status:
packets received: all 13387, UDP 13377, bad 0
packets sended: all 10437, UDP 10434, bad 0
parse errors: 0, mem errors 0, write errors 0
error flags: 0x0020
debug LED ptr: 0x0008
scratch: 0x0000
[space 7] LBP16 info:
LBP16 protocol version 3
board firmware version 15
IP address jumpers at boot: fixed from EEPROM
bengt@combimill:~$ ^C
bengt@combimill:~$
Communication:
Board info:
Connectors count: 3
Number of leds: 4
memory spaces:
[space 0] HostMot2
[space 4] timers:
WaituSReg: 0x0000
HM2Timeout: 0x0000
error flags: 0x0020
scratch: 0x0000
bengt@combimill:~$
Last edit: 27 Jul 2017 18:31 by tecno.
27 Jul 2017 18:33 #96589
by tecno
Output just do not switch to gnd but halshow let us know that output 15 is TRUE
Board failure?
Board failure?
27 Jul 2017 18:50 #96590
Outputs are not expected to switch to ground, they are sourcing outputs
27 Jul 2017 18:56 #96591
by tecno
OK thanks for correcting me. I have read wrong in manual and mixed inputs/outputs.
This is the famous language barrier and understanding other language. So back to the drawing board and do all rewiring.
27 Jul 2017 19:11 #96592
You can skip the firmware part, that is only needed for the older style boards that download firmware to the FPGA every startup.
27 Jul 2017 20:27 #96597
by tecno
Done schematics ready for rewiring job tomorrow. Only 1 MURR relay to be polarity changed in safety relay package.
All outgoing control wires other ends have to be investigated if polarity change has to done and all + to relays to be changed to GND.
So hopefully all is well when done tomorrow.
27 Jul 2017 20:47 #96601
by tecno
So there is nothing to be concerned about with CR1 as it is version15 on my board, right?
Time to create page: 0.292 seconds
