Installing QtVCP
29 Jan 2023 15:07 #263167
by Pro_El
Replied by Pro_El on topic Installing QtVCP
Hello all
I have problem when i installed Designer 5.15.8
I have Debian Bookworm with LCNC 2.9.
I installed qtvcp from script for 2.9
But when i start qt from Terminal i get this:
cnc@am-082e5f06e065:~$ designer -qt=5
Qtvcp python plugin found: /home/cnc/.designer/plugins/python/qtvcp_plugin.py
[QtDesigner][INFO] Logging to: /home/cnc/qtdesigner.log (logger.py:107)
tool_mmap_user(): file open fail: No such file or directory
tool_mmap_user(): no mmap file,continuing
mmap tool data not available, continuing emc/usr_intf/axis/extensions/emcmodule.cc
link (updating variable file): No such file or directory
And when i try to use some of the widget (like GCodeGraphics), the QT designer crush and got this on the terminal:
File "/usr/lib/python3/dist-packages/OpenGL/latebind.py", line 43, in __call__
return self._finalCall( *args, **named )
TypeError: 'NoneType' object is not callable
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/qt5_graphics.py", line 760, in initializeGL
self.realize()
File "/usr/lib/python3/dist-packages/qt5_graphics.py", line 523, in realize
self.font_base, width, linespace = glnav.use_pango_font(self._font, 0, 128)
File "/usr/lib/python3/dist-packages/glnav.py", line 65, in use_pango_font
glBitmap(0, 0, 0, 0, 0, h-d, ''.encode())
File "/usr/lib/python3/dist-packages/OpenGL/latebind.py", line 47, in __call__
File "/usr/lib/python3/dist-packages/OpenGL/wrapper.py", line 700, in wrapperCall
raise err
File "/usr/lib/python3/dist-packages/OpenGL/wrapper.py", line 693, in wrapperCall
result = wrappedOperation( *cArguments )
File "/usr/lib/python3/dist-packages/OpenGL/platform/baseplatform.py", line 415, in __call__
return self( *args, **named )
File "/usr/lib/python3/dist-packages/OpenGL/error.py", line 230, in glCheckError
raise self._errorClass(
OpenGL.error.GLError: GLError(
err = 1285,
description = b'out of memory',
baseOperation = glBitmap,
pyArgs = (0, 0, 0, 0, 0, 23.0, b''),
cArgs = (0, 0, 0, 0, 0, 23.0, b''),
cArguments = (0, 0, 0, 0, 0, 23.0, b'')
Aborted
I cannot find on the forum some answers
Did i need some dependencies or to change some paths... or maybe is still early for bookworm..
thanks
self.realize()
raise err
err = 1285,
Aborted
thanks
29 Jan 2023 19:05 #263177
Replied by cmorley on topic Installing QtVCP
I see there are all kinds of opengl problems reported on bookworm for AXIS and Gladevcp.
Qtvcp uses much of the same code.
The following user(s) said Thank You: Pro_El
29 Jan 2023 19:32 #263179
by Pro_El
Thanks Chris
i will wait couple of months till bookworm become stable..
it is very convenient because we can install LCNC from synaptic
14 Sep 2023 19:22 #280770
by nwallace
Replied by nwallace on topic Installing QtVCP
I followed the instructions to install qtvcp in the first post but the LinuxCNC widgets do not show in the designer. I am using Bookworm and the latest build of LinuxCNC 2.9. I have been searching and found nothing recent about this issue. My guess is that I just don't have the plugin for it. Can I get some guidance on where to look from here? It is difficult searching for more information on this when I don't know what questions to ask.
14 Sep 2023 20:15 #280773
by nwallace
I fixed it by manually copying this file /usr/lib/python3/dist-packages/qtvcp/plugins/qtvcp_plugin.py to ~/.designer/plugins/python/
15 Sep 2023 02:08 #280802
that works, but using a link is better in case the file changes.
Time to create page: 0.090 seconds
