How to configure PPMC with EMC2 on 3 axis milling
08 Sep 2011 16:38 #13048
by BigJohnT
Replied by BigJohnT on topic Re:How to configure PPMC with EMC2 on 3 axis milling
jmelson wrote:
BigJohnT wrote:
I still am very limited in what I can do in git. Yes, I think I did put it in master. Is there a simple way to
It does sound to me that you put your change in master and not 2.5, if that is the case it will not be included with 2.5 by default. I always open a terminal before editing a doc and do a git branch to see what is the current branch that I'm working on.
also move these files the 2.5? I really need the git syntax, I've tried reading the git documents but am not able to make much sense of them.Jon
You can use git cherrypick to bring something backwards from master to 2.5... let me find the exact sequence.
08 Sep 2011 17:07 #13050
by BigJohnT
To cherrypick something
git checkout v2.5_branch
git cherry-pick [the commit ref but not with the r]
one of yours would be
git cherry-pick aaf39735ede6
I use git gui a lot as it makes it easy to switch branches and view commits by branch
to search git
gitk --grep=g98
to search git
gitk --grep=g98
08 Sep 2011 17:53 #13052
Replied by andypugh on topic Re:How to configure PPMC with EMC2 on 3 axis milling
BigJohnT wrote:
In "Visualise all branch history" in git-gui you can right-click to
cherry-pick a commit into the current branch.
08 Sep 2011 21:45 #13056
by BigJohnT
That sure makes it easy if your always committing to master when you should be committing to a branch. ![:) :)](/media/kunena/emoticons/smile.png)
Time to create page: 0.075 seconds
