Threads
06 Oct 2011 13:10 #13702
by BigJohnT
Replied by BigJohnT on topic Re:Threads
I would just use the servo-thread, adding another thread has to be a multiple or something like that of the base thread.
www.linuxcnc.org/docview/html/config_ini_config.html#sub:[EMCMOT]-section
06 Oct 2011 13:23 #13704
by fma
Replied by fma on topic Re:Threads
The problem is that I get far too much values, as sampler will sample every servo-thread period, leading to a huge file. I only need 5-10 samples per second...
06 Oct 2011 14:33 #13708
by BigJohnT
Just a debounce to get the sample rate you want.
www.linuxcnc.org/docview/html/man/man9/debounce.9.html
06 Oct 2011 15:15 #13709
by fma
Ok, but how to I connect the deboucner to the sampler? AFAIK, the sampler samples each time its function is called by the thread...
06 Oct 2011 17:12 #13711
by BigJohnT
Which component is the sampler?
06 Oct 2011 21:07 #13717
by fma
06 Oct 2011 23:44 #13718
by BigJohnT
Cool, you might try debounce connected to the enable pin on sampler... I've never used it before.
07 Oct 2011 06:24 #13733
by fma
Ah, yes, that's a good idea! Thank!
07 Oct 2011 09:29 - 07 Oct 2011 09:30 #13736
by fma
In order to work, the sampler enable pin needs to be true only during 1 clock cycle, otherwise it will generate several samples. The debouncer does not allow that, does it?
So, I think I will have to write a special component, which will generate that single pulse. Something like:
What do you think?
component divider "Divide the 'clock' signal of the thread by some amount";
pin in bit enable=TRUE "enable divider";
pin out bit pulse=FALSE "pulse output";
param u32 divider=10000 "divider value";
variable u32 counter = 0;
function _;
license "GPL";
author "fma";
FUNCTION(_)
if (enable) {
counter += 1;
if counter == divider {
pulse = TRUE;
counter = 0;
else {
pulse = FALSE;
Last edit: 07 Oct 2011 09:30 by fma.
Time to create page: 0.319 seconds
