Threads
07 Oct 2011 10:22 #13738
by kostas
Replied by kostas on topic Re:Threads
Maybe you could use a oneshot component before the enable pin, for generating the one clock pulse needed?
07 Oct 2011 10:31 #13739
by fma
Replied by fma on topic Re:Threads
The problem is to generate the trigger signal...
07 Oct 2011 10:57 #13741
by fma
Ok, I found: siggen!
Question: in the oneshot comp, does width=0 mean the minimum duration of the out signal?
07 Oct 2011 13:29 #13751
Replied by andypugh on topic Re:Threads
Yes, 0 = one thread invocation.
I am surprised that sampler doesn't feature a divider parameter. I think that somebody should add one.
07 Oct 2011 17:24 #13764
by fma
I'll have a look at that comp, and see if I can add this feature...
14 Oct 2011 07:12 #13906
by fma
I finally wrote a clock comp, which has both normal 50% duty cycle output pin and pulse output pin. The pulse pin remains TRUE only for 1 thread cycle. Connecting this pulse output to the sampler.enable pin does the job.
Here is the code; feel free to comment it:
component clock "Generate a clock signal";
pin in bit enable=TRUE "enable clock";
pin out bit out=FALSE "50% duty cycle clock output";
pin out bit pulse=FALSE "pulse clock output";
param rw unsigned freq=1000 "clock frequency";
function _ nofp;
// Global Variables
variable unsigned total_nsec = 0;
license "GPL";
author "fma";
FUNCTION(_)
if (enable) {
if (total_nsec == 0) {
out = TRUE;
pulse = TRUE;
else {
pulse = FALSE;
if (total_nsec >= (1000000000 / freq / 2)) {
out = FALSE;
total_nsec += period;
if (total_nsec >= (1000000000 / freq)) {
total_nsec = 0;
17 Oct 2011 08:01 - 17 Oct 2011 08:09 #13966
by fma
Oups, there is an issue in the previous code: I inverted the frequency computation...
Anyway, here is a new version, using fp, allowing freq. < 1:
param rw float freq=1000 "clock frequency";
function _ fp;
// Global variables
variable double total_sec = 0.;
license "GPL";
author "fma";
FUNCTION(_)
if (enable) {
if (total_sec == 0.) {
out = TRUE;
pulse = TRUE;
else {
pulse = FALSE;
if (total_sec >= (2. / freq)) {
out = FALSE;
total_sec += fperiod;
if (total_sec >= (1. / freq)) {
total_sec = 0.;
Last edit: 17 Oct 2011 08:09 by fma. Reason: Changed total_sec from float to double
Time to create page: 0.101 seconds
