comp a function - sudo apt-get linuxcnc-dev
04 Apr 2012 11:52 - 04 Apr 2012 12:06 #18963
by Fremder
comp a function - sudo apt-get linuxcnc-dev was created by Fremder
Hi ..
to make a function and compile:
i must do this:
sudo comp --install xyz.c
but on my system its not the comp (path) installed ... what i must do ?
![;-) ;-)](/media/kunena/emoticons/wink.png)
the linuxcnc.org/docs/html/hal/comp.html its ok for the code ... but i found
sudo apt-get linuxcnc-dev (i see in the help on the googlesides ...)
and its not work ...
thanks for help
sudo apt-get install emc2-dev
# its ok ... i hope
i must do this:
thanks for help
# its ok ... i hope
Last edit: 04 Apr 2012 12:06 by Fremder.
04 Apr 2012 11:56 - 04 Apr 2012 11:57 #18964
by BigJohnT
Replied by BigJohnT on topic Re:comp a function - sudo apt-get linuxcnc-dev
Fremder wrote:
Can you be a bit more specific about what didn't work?
Also the install command is for a .comp file not a .c file.
Last edit: 04 Apr 2012 11:57 by BigJohnT.
04 Apr 2012 12:09 #18965
by Fremder
Replied by Fremder on topic Re:comp a function - sudo apt-get linuxcnc-dev
comp: command not found
was the "error" in the terminal ...
i make this
and now its going ... i think its the old "emc2" but the new with
its not actuall
thanks for your FAST answer ,-)
but cut
i make this
its not actuall
but cut
04 Apr 2012 13:24 #18966
by BigJohnT
If you upgraded to 2.5 I think you should remove 2.4 in the synaptic package manager. If you still have 2.4 installed then yes it is still emc2-dev.
So are you up and running now?
04 Apr 2012 14:18 #18967
by Fremder
good think ![:) :)](/media/kunena/emoticons/smile.png)
its now emc2-dev ... its i hope no problem for the future ...
or its better completly update to 2.5.x ...
actual i install the emc2 packeage - from the git -
here its the em2-dev named !?
i'll make a simple c-function with hal and other
but without the cource from emc2/linuxcnc i have no rtapi.h / hal.h / streamer.h
its my "way" the right to make the functions in c and i ~must~ install the git / source complet ?
thanks
![:-) :-)](/media/kunena/emoticons/smile.png)
04 Apr 2012 15:27 - 04 Apr 2012 15:31 #18969
by ArcEye
Replied by ArcEye on topic Re:comp a function - sudo apt-get linuxcnc-dev
Hi
It is a bit hard to understand what you are asking or saying.
If you want to write components and develop generally, you will need several things
Linux-2.6.32 source
linux-headers-2.6.32-122
linux-headers-2.6.32-122-rtai
build-essentials
I would recommend that you download the latest stable version of linuxcnc 2.5 source code from buildbot.linuxcnc.org/
and build it as a Run In Place configuration in /usr/src and do all your development from there.
(wiki.linuxcnc.org/cgi-bin/wiki.pl?Installing_LinuxCNC tells you how to build RIP)
That way everything is self contained, all the source and libraries you need are there, without any danger of overwriting the installed files from the 2.4.6 debs.
You can compile a C file if you like, but there is no reason to do so and it is completely re-inventing the wheel.
Much easier to write the C routine in the FUNCTION() portion of the .comp and leave the comp macros to generate the rest for you.
Linux-2.6.32 source
build-essentials
Last edit: 04 Apr 2012 15:31 by ArcEye.
04 Apr 2012 16:29 #18973
by Fremder
Hi ArcEye
its not verry importend actual - for >interesting< i install the full git ..
but the troubles to much![:-) :-)](/media/kunena/emoticons/smile.png)
: yours: Much easier to write the C routine in the FUNCTION() portion of the .comp and leave the comp macros to generate the rest for you.
its there a "PATH" for the comp(iling) the c file - when inside a #include "rtapi.h" ... / hal.h ?
btw. can i copy the rtapi.h / hal.h in the directory from the C file ? and then
thanks for your help
04 Apr 2012 17:19 - 05 Apr 2012 08:12 #18975
by ArcEye
I have no idea what you are trying to write, but you are making things too difficult for yourself.
Save this simple example into a file called test.comp
Then run comp test.comp and it will generate test.c
Reading this will show you exactly what the comp program does to generate code to produce a module.
You can then build a module with comp --install test.comp
From the commandline
$ # halrun
halcmd: loadrt test
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
4 bit IN FALSE test.0.testinbit
4 s32 IN 0 test.0.testins32
4 bit OUT FALSE test.0.testoutbit
4 s32 OUT 0 test.0.testouts32
halcmd: unloadrt test
halcmd: exit
Which will demonstrate that the module loads and the pins were created.
Now just use this as a template and replace pins and variables with what you want and replace the code in FUNCTION() with something meaningful.
The code in FUNCTION() needs to do something and return quickly, no calls to sleep(), no while() loops etc.
Hence why a switch() statement, allowing you to do something, change the progress_level and next visit do the next stage and so on, is useful for a module which checks state of the pins and does stuff dependent upon that state.
Simple as that (in theory)![:woohoo: :woohoo:](/media/kunena/emoticons/w00t.png)
component test "This is a test component";
pin in bit testinbit;
pin in s32 testins32;
pin out bit testoutbit;
pin out s32 testouts32;
param rw s32 testrwparam = 0;
// internal variables
variable bool testbool = false;
variable float testfloat = 0;
variable int progress_level = 0;
function _;
author "ArcEye ";
license "GPL";
FUNCTION(_)
switch (progress_level)
case 0:
break;
default:
rtapi_print_msg(RTAPI_MSG_ERR, "Unknown state");
break;
$ # halrun
halcmd: loadrt test
halcmd: show pin
Component Pins:
halcmd: exit
Last edit: 05 Apr 2012 08:12 by ArcEye.
The following user(s) said Thank You: kagouraki
05 Apr 2012 15:05 #18992
by Fremder
thanks for your sample... its going ...
but i have a full new (Nr. 101) installation make - to many progams installd....
after update to 2.5x
install gladevcp and the others
i found no way to make the gladefiles with *.UI ???
the 1000 sides with emc2/linuxcnc make me trouble ...
======== this is the actual link: from www.linuxcnc.org/docs/2.5/html/gui/gladevcp.html
3. Creating and Integrating a Glade user interface
3.1. Prerequisite: Glade installation
To view or modify Glade UI files, you need glade installed - it is not needed just to run a GladeVCP panel. If the glade command is missing, install it with the command:
$ sudo apt-get install glade
Verify the version number to be greater than 3.6.7:
$ glade --version
glade3 3.6.7
i have this. version its ok ... but now files are with *.ui going.
sorry ... i think its a smal "think" to do but a LOOOOONG way for me ,-)
can help
thanks
$ glade --version
glade3 3.6.7
can help
thanks
05 Apr 2012 15:32 #18994
by ArcEye
.ui stands for 'user interface' and are a common extension used by GUI creating software like QT Designer or Glade for their output files.
If you want to create one, just open Glade and create an interface and it will be saved as something.ui
If you want to open and or edit one open glade and File>Open and choose the .ui file
Anything deeper on Glade you need to ask in Linuxcnc Forum > Configuring Linuxcnc > GladeVCP
I have found pyVCP adequate for all my needs so far and have avoided it and all its pythonic twists.
Sorry, don't know what you are asking.. but now files are with *.ui going
