hm2-5i20 errorlog
04 May 2012 06:09 #19791 by KobeYang
hm2-5i20 errorlog was created by KobeYang
Hello all,
I use emc2 2.4.6 with mesa 5i20 card,but I get the error as following:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.4
EMC2 - 2.4.6
Machine configuration directory is '/home/apizc/emc2/configs/hm2-servo'
Machine configuration file is '5i20.ini'
INIFILE=/home/apizc/emc2/configs/hm2-servo/5i20.ini
PARAMETER_FILE=hm2-servo.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=5459
Cleanup done
Debug file information:
inifile: warning: File contains DOS-style line endings.
hm2-servo.hal:25: Warning: File contains DOS-style line endings.
hm2-servo.hal:51: parameter or pin 'hm2_5i20.0.pwmgen.pwm_frequency' not found
5459
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 192.720970] I-pipe: Domain RTAI registered.
[ 192.720975] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 192.720976] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[ 192.720979] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 192.720980] PIPELINE layers:
[ 192.720982] f8b35000 9ac15d93 RTAI 200
[ 192.720983] c0383180 0 Linux 100
[ 192.726769] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 192.729803] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 192.729806] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[ 192.729808] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 2600185000 hz.
[ 192.729810] RTAI[sched]: timer setup = 2010 ns, resched latency = 2689 ns.
[ 192.751921] RTAI[math]: loaded.
[ 192.826309] hm2: loading Mesa HostMot2 driver version 0.15
[ 192.839141] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.6
[ 192.839811] hm2_pci: discovered 5i20 at 0000:02:0f.0
[ 192.973653] hm2/hm2_5i20.0: invalid config name, got 'HOQTMOT2', expected 'HOSTMOT2'
[ 192.973657] hm2_5i20.0: board fails HM2 registration
[ 192.974296] hm2_pci: probe of 0000:02:0f.0 failed with error -22
[ 193.092897] hm2_pci: driver unloaded
[ 193.100729] hm2: unloading
[ 195.200034] RTAI[math]: unloaded.
[ 195.234655] SCHED releases registered named ALIEN RTGLBH
[ 195.247901] RTAI[malloc]: unloaded.
[ 195.347499] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 195.349748] I-pipe: Domain RTAI unregistered.
[ 195.349753] RTAI[hal]: unmounted.
I don't know what's mean of "[ 192.973653] hm2/hm2_5i20.0: invalid config name, got 'HOQTMOT2', expected 'HOSTMOT2'",and I didn't find "HOQTMOT2" in the ini file and hal file.can you help me,thanks.
04 May 2012 06:12 #19793 by cmorley
Replied by cmorley on topic Re:hm2-5i20 errorlog
post your HAL file please
04 May 2012 06:21 #19794 by KobeYang
Replied by KobeYang on topic Re:hm2-5i20 errorlog
# HAL file for HostMot2 with 4 servos
# Derived from Ted Hyde's original hm2-servo config
# Based up work and discussion with Seb & Peter & Jeff
# GNU license references - insert here. www.linuxcnc.org
# Firmware files are in /lib/firmware/hm2/7i43/
# Must symlink the hostmot2 firmware directory of sanbox to
# /lib/firmware before running EMC2...
# sudo ln -s $HOME/emc2-sandbox/src/hal/drivers/mesa-hostmot2/firmware /lib/firmware/hm2
# See also:
# <www.linuxcnc.org/docs/devel/html/man/man...ml#config%20modparam>
# and wiki.linuxcnc.org/cgi-bin/emcinfo.pl?HostMot2
# Core EMC/HAL Loads
# kinematics
loadrt trivkins
# motion controller, get name and thread periods from ini file
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
# standard components
loadrt pid num_chan=3
# only the 7i43 needs this, but it doesnt hurt the others
loadrt probe_parport
# hostmot2 driver
# if you have any firmware trouble, enable the debug flags here and see what's going on in the syslog
#loadrt hostmot2 debug_idrom=1 debug_module_descriptors=1 debug_pin_descriptors=1 debug_modules=1
loadrt hostmot2
loadusr joystick
loadusr drodmis
loadusr limittrans
loadrt enableprobe
loadrt stopsign
loadrt mux2 count=1
# load low-level driver
loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG)
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.pwm_frequency 40000
setp hm2_[HOSTMOT2](BOARD).0.watchdog.timeout_ns 10000000
# THREADS
addf hm2_[HOSTMOT2](BOARD).0.read servo-thread
addf stopsign.0 servo-thread
addf enableprobe.0 servo-thread
addf pid.0.do-pid-calcs servo-thread
addf pid.1.do-pid-calcs servo-thread
addf pid.2.do-pid-calcs servo-thread
addf mux2.0 servo-thread
addf hm2_[HOSTMOT2](BOARD).0.write servo-thread
addf hm2_[HOSTMOT2](BOARD).0.pet_watchdog servo-thread
# Axis-of-motion Specific Configs (not the GUI)
# halui parameter
#setp halui.jog-speed 6000
setp halui.jog-deadband 0
setp mux2.0.in0 6000
setp mux2.0.in1 3000
# X [0] Axis
# axis enable chain
newsig emcmot.00.enable bit
sets emcmot.00.enable FALSE
net emcmot.00.enable => pid.0.enable
net emcmot.00.enable => hm2_[HOSTMOT2](BOARD).0.pwmgen.00.enable
net emcmot.00.enable <= axis.0.amp-enable-out
# encoder feedback
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.counter-mode 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.filter 1
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.index-invert 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.index-mask 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.index-mask-invert 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.scale [AXIS_0]INPUT_SCALE
net motor.00.pos-fb hm2_[HOSTMOT2](BOARD).0.encoder.00.position => pid.0.feedback
net motor.00.pos-fb => axis.0.motor-pos-fb #push copy back to Axis GUI
net xsvr hm2_[HOSTMOT2](BOARD).0.gpio.036.in => stopsign.0.xsvr
# set PID loop gains from inifile
setp pid.0.Pgain [AXIS_0]P
setp pid.0.Igain [AXIS_0]I
setp pid.0.Dgain [AXIS_0]D
setp pid.0.bias [AXIS_0]BIAS
setp pid.0.FF0 [AXIS_0]FF0
setp pid.0.FF1 [AXIS_0]FF1
setp pid.0.FF2 [AXIS_0]FF2
setp pid.0.deadband [AXIS_0]DEADBAND
setp pid.0.maxoutput [AXIS_0]MAX_OUTPUT
# position command signals
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.00.output-type 1 #pwm on pin1, dir on pin2
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.00.scale [AXIS_0]OUTPUT_SCALE
net emcmot.00.pos-cmd axis.0.motor-pos-cmd => pid.0.command
net motor.00.command pid.0.output => hm2_[HOSTMOT2](BOARD).0.pwmgen.00.value
net jstk.axis.0.vel JOYJB200.axis.0.output => halui.jog.0.analog
net pos.0.fb axis.0.joint-pos-fb => JOYJB200.axis.0.position DRODMIS.axis.0.pos
# Y [1] Axis
# axis enable chain
newsig emcmot.01.enable bit
sets emcmot.01.enable FALSE
net emcmot.01.enable => pid.1.enable
net emcmot.01.enable => hm2_[HOSTMOT2](BOARD).0.pwmgen.01.enable
net emcmot.01.enable <= axis.1.amp-enable-out
# encoder feedback
setp hm2_[HOSTMOT2](BOARD).0.encoder.01.counter-mode 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.01.filter 1
setp hm2_[HOSTMOT2](BOARD).0.encoder.01.index-invert 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.01.index-mask 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.01.index-mask-invert 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.01.scale [AXIS_1]INPUT_SCALE
net motor.01.pos-fb hm2_[HOSTMOT2](BOARD).0.encoder.01.position => pid.1.feedback
net motor.01.pos-fb => axis.1.motor-pos-fb #push copy back to Axis GUI
net ysvr hm2_[HOSTMOT2](BOARD).0.gpio.037.in => stopsign.0.ysvr
setp pid.1.Pgain [AXIS_1]P
setp pid.1.Igain [AXIS_1]I
setp pid.1.Dgain [AXIS_1]D
setp pid.1.bias [AXIS_1]BIAS
setp pid.1.FF0 [AXIS_1]FF0
setp pid.1.FF1 [AXIS_1]FF1
setp pid.1.FF2 [AXIS_1]FF2
setp pid.1.deadband [AXIS_1]DEADBAND
setp pid.1.maxoutput [AXIS_1]MAX_OUTPUT
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.01.output-type 1 #pwm on pin1, dir on pin2
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.01.scale [AXIS_1]OUTPUT_SCALE
net emcmot.01.pos-cmd axis.1.motor-pos-cmd => pid.1.command
net motor.01.command pid.1.output => hm2_[HOSTMOT2](BOARD).0.pwmgen.01.value
net jstk.axis.1.vel JOYJB200.axis.1.output => halui.jog.1.analog
net pos.1.fb axis.1.joint-pos-fb => JOYJB200.axis.1.position DRODMIS.axis.1.pos
# Z [2] Axis
# axis enable chain
newsig emcmot.02.enable bit
sets emcmot.02.enable FALSE
net emcmot.02.enable => pid.2.enable
net emcmot.02.enable => hm2_[HOSTMOT2](BOARD).0.pwmgen.02.enable
net emcmot.02.enable <= axis.2.amp-enable-out
# encoder feedback
setp hm2_[HOSTMOT2](BOARD).0.encoder.02.counter-mode 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.02.filter 1
setp hm2_[HOSTMOT2](BOARD).0.encoder.02.index-invert 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.02.index-mask 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.02.index-mask-invert 0
setp hm2_[HOSTMOT2](BOARD).0.encoder.02.scale [AXIS_2]INPUT_SCALE
net motor.02.pos-fb hm2_[HOSTMOT2](BOARD).0.encoder.02.position => pid.2.feedback
net motor.02.pos-fb => axis.2.motor-pos-fb #push copy back to Axis GUI
net zsvr hm2_[HOSTMOT2](BOARD).0.gpio.038.in => stopsign.0.zsvr
setp pid.2.Pgain [AXIS_2]P
setp pid.2.Igain [AXIS_2]I
setp pid.2.Dgain [AXIS_2]D
setp pid.2.bias [AXIS_2]BIAS
setp pid.2.FF0 [AXIS_2]FF0
setp pid.2.FF1 [AXIS_2]FF1
setp pid.2.FF2 [AXIS_2]FF2
setp pid.2.deadband [AXIS_2]DEADBAND
setp pid.2.maxoutput [AXIS_2]MAX_OUTPUT
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.02.output-type 1 #pwm on pin1, dir on pin2
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.02.scale [AXIS_2]OUTPUT_SCALE
net emcmot.02.pos-cmd axis.2.motor-pos-cmd => pid.2.command
net motor.02.command pid.2.output => hm2_[HOSTMOT2](BOARD).0.pwmgen.02.value
net jstk.axis.2.vel JOYJB200.axis.2.output => halui.jog.2.analog
net pos.2.fb axis.2.joint-pos-fb => JOYJB200.axis.2.position DRODMIS.axis.2.pos
# Standard I/O Block - EStop, Etc
# create a signal for the estop loopback net stop-signal hm2_[HOSTMOT2](BOARD).0.gpio.065.in => stopsign.0.jstop
#net estop-loop iocontrol.0.user-enable-out => iocontrol.0.emc-enable-in
net estop-loop stopsign.0.out => iocontrol.0.emc-enable-in
# create signals for tool loading loopback
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed
# homing
# EMC expects the value on the .home-sw-in HAL pin to be active high, ie
# True when the switch is closed and False when the switch is open.
# We get this behavior by linking the GPIO .in_not pin instead of the .in
# pin.
#axis.0.home-sw-in
#axis.1.home-sw-in
#axis.2.home-sw-in
net home-switch-0 hm2_[HOSTMOT2](BOARD).0.gpio.057.in_not => LIMITTRANS.xlimitin
net home-switch-1 hm2_[HOSTMOT2](BOARD).0.gpio.058.in_not => LIMITTRANS.ylimitin
net home-switch-2 hm2_[HOSTMOT2](BOARD).0.gpio.059.in_not => LIMITTRANS.zlimitin
net y-index-enable hm2_[HOSTMOT2](BOARD).0.encoder.01.index-enable <=> axis.1.index-enable pid.1.index-enable
net z-index-enable hm2_[HOSTMOT2](BOARD).0.encoder.02.index-enable <=> axis.2.index-enable pid.2.index-enable
net x-index-enable hm2_[HOSTMOT2](BOARD).0.encoder.00.index-enable <=> axis.0.index-enable pid.0.index-enable
# probe sign
setp hm2_[HOSTMOT2](BOARD).0.gpio.066.is_output 1
setp hm2_[HOSTMOT2](BOARD).0.gpio.068.is_output 1
setp hm2_[HOSTMOT2](BOARD).0.gpio.056.is_output 1
#setp hm2_[HOSTMOT2](BOARD).0.gpio.066.invert_output 1
net probe_test hm2_[HOSTMOT2](BOARD).0.gpio.071.in => hm2_[HOSTMOT2](BOARD).0.encoder.00.latch-enable hm2_[HOSTMOT2](BOARD).0.encoder.01.latch-enable hm2_[HOSTMOT2](BOARD).0.encoder.02.latch-enable hm2_[HOSTMOT2](BOARD).0.gpio.056.out
net probet hm2_[HOSTMOT2](BOARD).0.gpio.071.in_not => JOYJB200.probesign hm2_[HOSTMOT2](BOARD).0.gpio.068.out DRODMIS.probesign
# Spindle Setting
#net spindle-cmd <= motion.spindle-speed-out => hm2_[HOSTMOT2](BOARD).0.pwmgen.05.value
net spindle-enable <= motion.spindle-on => hm2_[HOSTMOT2](BOARD).0.pwmgen.05.enable
net ssvr hm2_[HOSTMOT2](BOARD).0.gpio.041.in => stopsign.0.ssvr
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.05.output-type 1 #pwm on pin1, dir on pin2
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.05.scale 3000
# limit Setting
net xneglim LIMITTRANS.xneglimit => axis.0.neg-lim-sw-in
net xposlim LIMITTRANS.xposlimit => axis.0.pos-lim-sw-in
net yneglim LIMITTRANS.yneglimit => axis.1.neg-lim-sw-in
net yposlim LIMITTRANS.yposlimit => axis.1.pos-lim-sw-in
net zneglim LIMITTRANS.zneglimit => axis.2.neg-lim-sw-in
net zposlim LIMITTRANS.zposlimit => axis.2.pos-lim-sw-in
04 May 2012 06:24 #19795 by cmorley
sorry I will need the ini file too
04 May 2012 06:26 #19796 by KobeYang
[HOSTMOT2]
DRIVER=hm2_pci
BOARD=5i20
CONFIG="firmware=hm2/5i20/5I20_SVST8_3P.BIT num_encoders=3 num_pwmgens=6 num_stepgens=0"
[EMC]
# Name of machine, for use with display, etc.
MACHINE = APIZC 5Axis_Milling
# Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others
#DEBUG = 0x00000003
#DEBUG = 0x00000007
DEBUG = 0
[DISPLAY]
# Name of display program, e.g., tkemc
DISPLAY = axis
PYVCP = mypanel.xml
# Cycle time, in seconds, that display will sleep between polls
CYCLE_TIME = 0.0500
# Path to help file
HELP_FILE = tkemc.txt
# Initial display setting for position, RELATIVE or MACHINE
POSITION_OFFSET = MACHINE
# Initial display setting for position, COMMANDED or ACTUAL
POSITION_FEEDBACK = ACTUAL
# Highest value that will be allowed for feed override, 1.0 = 100%
MAX_FEED_OVERRIDE = 1.1
# Prefix to be used
PROGRAM_PREFIX = /home/apizc/emc2/nc_files
# Introductory graphic
INTRO_TIME = 5
[TASK]
# Name of task controller program, e.g., milltask
TASK = milltask
# Cycle time, in seconds, that task controller will sleep between polls
CYCLE_TIME = 0.010
[RS274NGC]
# File containing interpreter variables
PARAMETER_FILE = hm2-servo.var
[EMCMOT]
EMCMOT = motmod
# Timeout for comm to emcmot, in seconds
COMM_TIMEOUT = 1.0
# Interval between tries to emcmot, in seconds
COMM_WAIT = 0.010
# Servo task period, in nanoseconds
SERVO_PERIOD = 1000000
[HAL]
# The run script first uses halcmd to execute any HALFILE
# files, and then to execute any individual HALCMD commands.
# list of hal config files to run through halcmd
# files are executed in the order in which they appear
HALUI = halui
HALFILE = hm2-servo.hal
POSTGUI_HALFILE=customerconfig.hal
# list of halcmd commands to execute
# commands are executed in the order in which they appear
#HALCMD = save neta
[TRAJ]
AXES = 3
# COORDINATES = X Y Z R P W
COORDINATES = X Y Z
HOME = 0 0 0 0
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 100
MAX_VELOCITY = 200
DEFAULT_ACCELERATION = 400
MAX_ACCELERATION = 400
[AXIS_0]
TYPE = LINEAR
MAX_VELOCITY = 200
BACKLASH = 0.000
FERROR = 200
MIN_FERROR = 150
INPUT_SCALE = -999.98966
OUTPUT_SCALE = 250
OUTPUT_OFFSET = 0
MAX_OUTPUT = 200
MIN_LIMIT = -3
MAX_LIMIT = 7010
HOME = 0
HOME_OFFSET = 0
#HOME_SEARCH_VEL = -10
#HOME_LATCH_VEL = 10
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = -10
# the X axis servo's encoder does not have an index channel, so we have to home without index
HOME_USE_INDEX = YES
HOME_IGNORE_LIMITS = NO
# PID tuning params
DEADBAND = 0.000015
P = 20
I = 0
D = 0
FF0 = 0.000
FF1 = 0.5
FF2 = 0.0
BIAS = 0.000
[AXIS_1]
TYPE = LINEAR
MAX_VELOCITY = 200
BACKLASH = 0.000
FERROR = 200
MIN_FERROR = 150
INPUT_SCALE = -999.95326
OUTPUT_SCALE = 250
OUTPUT_OFFSET = 0
MAX_OUTPUT = 200
MIN_LIMIT = -1410
MAX_LIMIT = 3
HOME = 0
HOME_OFFSET = 0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 10
# the Y axis servo's encoder has an index channel, so we use it to improve the home accuracy
# PID tuning params
DEADBAND = 0.000015
P = 20
I = 0
D = 0.000
FF0 = 0.000
FF1 = 0.5
FF2 = 0.0
BIAS = 0.000
[AXIS_2]
TYPE = LINEAR
MAX_VELOCITY = 200
BACKLASH = 0.000
FERROR = 200
MIN_FERROR = 150
INPUT_SCALE = -1000.0200
OUTPUT_SCALE = -250
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 200
MIN_LIMIT = -2010
MAX_LIMIT = 3
HOME = 0
HOME_OFFSET = 0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 10
# the Z axis servo's encoder does not have an index channel, so we have to home without index
# PID tuning params
DEADBAND = 0.000015
P = 20
I = 0
D = 0.000
FF0 = 0.000
FF1 = 0.5
FF2 = 0.0
BIAS = 0.000
[EMCIO]
# Name of IO controller program, e.g., io
EMCIO = io
# cycle time, in seconds
CYCLE_TIME = 0.100
# tool table file
TOOL_TABLE = tool.tbl
04 May 2012 06:36 #19797 by cmorley
hmmm I can't find anything obvious...
If I had to guess, I would say there is corrupted data on the Mesa board or maybe the firmware?
Did this board every work ?
I'm sorry you'll have to wait for someone who knows more about firmware loading.
04 May 2012 06:39 #19798 by KobeYang
the card works well for a long time,I don't know what wrong with it.Thanks a lot.
04 May 2012 07:20 - 04 May 2012 07:34 #19801 by cncbasher
Replied by cncbasher on topic Re:hm2-5i20 errorlog
did you re save the ini and hal files the seem to be previously saved in windows format etc
see -
so resave the files using gedit etc and change the line endings to be linux and you should find your ok
these errors are around as you can see line 25 & 51 in your hal file
this would stop the ini file loading the driver .
editing or transfering your hal files on a windows machine and sending by email etc to your linuxcnc can cause this if your not careful
Last edit: 04 May 2012 07:34 by cncbasher.
04 May 2012 10:26 #19802 by andypugh
Replied by andypugh on topic Re:hm2-5i20 errorlog
If you look at line 1140 onwards here: git.linuxcnc.org/gitweb?p=linuxcnc.git;a...-hostmot2/hostmot2.c
It looks like the config name is read out of the FPGA memory, and in your case the wrong value is being read back.
This almost certainly indicates a corrupted bitfile.
sudo apt-get install emc-firmware
is likely to fix the problem. (possibly after an apt-get remove to clear out the old versions)
04 May 2012 14:51 - 04 May 2012 15:46 #19807 by PCW
Replied by PCW on topic Re:hm2-5i20 errorlog
If nothing else was changed when it stopped working I would suspect the 5I20 card/PC or PCI connector
I would try removing the 5I20 card, cleaning the contact fingers with 99% isopropyl alchohol
and reseating it. It looks like bad pci/localbus interface bit (bit 18 open/stuck low) but this would need to be confirmed
by additional tests.
BTW This error is very unlikely to be caused by a corrupted bitfile, as the FPGA CRC checks the bitlfile as it is loaded
and will not start if there is a CRC error.
Last edit: 04 May 2012 15:46 by PCW. Reason: clarify
Time to create page: 0.094 seconds
