hm2-5i20 errorlog
04 May 2012 15:02 #19808
Replied by andypugh on topic Re:hm2-5i20 errorlog
PCW wrote:
Perhaps there should be an FFFFFFFF and 00000000 pattern in the test sequence too?
Ah, yes, because that bit is low anyway in the letter "T" so the problem doesn't show up there in the second "T".(bit 18 open/stuck low)
04 May 2012 15:13 #19810
Replied by PCW on topic Re:hm2-5i20 errorlog
(or true and inverted cookie)
Of course the driver bails at the first error but theres also a 32 bit cookie that is checked later
its arguable that there should be a IDROM checksum as well, but its pretty unlikely to have
the PCI ID, "HOSTMOT2", CARDNAME, and COOKIE alll correct and still have a data bus error
05 May 2012 08:21 #19831
by KobeYang
Replied by KobeYang on topic Re:hm2-5i20 errorlog
I reseat the card and it works well now,Thank you very much:)
