OpenCV vision with EMC/linuxcnc
27 May 2012 16:11 #20448
by cncbasher
Replied by cncbasher on topic Re:OpenCV vision with EMC/linuxcnc
my thoughts are to implement a sift algorithym to compare smd shape profiles from a database ( this way it's easier to add a footprint from a pcb package)
and use the vision to orient the part to the pcb , hardware is not too difficult , and my thoughts are to use solinoids for the part reels set so one action moves the tape one part , more of a fixed rotation cam , the lifter is just the standard vacuum type on a small servo motor .
i'm looking at using the standard cam file type inputs from eagle ...
- tom.larkworthy
13 Jun 2012 12:09 #20872
by tom.larkworthy
Replied by tom.larkworthy on topic Re:OpenCV vision with EMC/linuxcnc
Hi! What a great thread. I am working toward a very similar goal:
edinburghhacklab.com/2012/05/optical-loc...o-0-1mm-no-problemo/
While I am doing optics for a robot arm, I am thinking I should upgrade my CNC while I am at it and stumbled across this thread. I was about to intergrate the robot operating system ros.org with linuxCNC. (ROS is maintained by Willow Garage who also maintain OpenCV). Anyway, I would be happy to collaborate getting this working. I don't expect it to take too long (4 weeks?) as I have the vision stuff built already. I just need the ROS to linuxCNC bridge built which is pretty trivial if done in python (ROS works with python and C++, we can switch later if we want).
Tom
Tom
13 Jun 2012 14:24 #20873
by cncbasher
Hi Tom ,
i was just looking at ros earlier today after a websearch and thought the same , in linking to linuxcnc .
Dave
Dave
- tom.larkworthy
13 Jun 2012 15:55 #20875
by tom.larkworthy
I am starting a new thread specifically for ROS integration as this one is really about OpenCV (although that is naturally integrated with ROS)
www.linuxcnc.org/index.php/english/compo...id=10&id=20874#20874
Time to create page: 0.090 seconds
