Servo Tuning Advice
- Topic Author
- Thank you received: 1370
01 Nov 2012 18:12 #26180
Replied by Todd Zuercher on topic Servo Tuning Advice
This is a wood working machine, so normal cutting feed speeds are a lot higher. Since this is going to mostly do 2.5-D Carving and engraving I am hoping that it won't matter to much.
- Topic Author
01 Nov 2012 23:08 #26187
Might there be any advantage to messing with the Traj period? My hal and ini files do not currently have any reference to it.
02 Jan 2013 01:25 #28269
by mhaberler
Replied by mhaberler on topic Servo Tuning Advice
I made a stab to fix this error, please see here:
git.mah.priv.at/gitweb/emc2-dev.git/comm...276efd65f62684b77f57 :
motion: introduce motion.ferror-mode
by default (motion.ferror-mode == 0), ferror is computed based on the last commanded position, which is problematic with velocity-mode drives
if motion.ferror-mode == 1, ferror is calculated based on the new commanded position, and following error checks are postponed until after the new commanded position is calculated.
based on v2.5_branch . this is untested on a real machine.
please let me know if this makes a difference if you
setp motion.ferror-mode 1
- Michael
- Michael
02 Jan 2013 17:42 #28297
by mhaberler
further to the aforementioned patch, here are two halscope shots taken off a stepper servo config - there is some indication that the patch does what we want:
scoping axis.0.error and pid.0.error
motion.ferror-mode set to 0:
static.mah.priv.at/public/motion-ferror-mode-0.jpg
note wildly diverging shapes
motion.ferror-mode set to 1:
static.mah.priv.at/public/motion-ferror-mode-1.jpg
pretty commensurate
- Michael
pretty commensurate
- Michael
- Topic Author
02 Jan 2013 21:14 #28303
Could I get some brief instructions how to apply the patch?
I can't say for sure if I will test it, as the machine in question has been working acceptibly for a month or two, and I have s back log of work I need to catch up on.
02 Jan 2013 21:30 #28305
by mhaberler
I'll push this through the buildbot so we should have a package to test shortly
are you running 2.5 or master?
- Michael
- Michael
- Topic Author
02 Jan 2013 23:05 #28312
I'm running 2.5
03 Jan 2013 00:06 #28318
by mhaberler
the ferror-mode 2.5-based RIP package is now online: buildbot.linuxcnc.org/dists/lucid/scratc...binary-i386/?C=M;O=D
I think it's this one: buildbot.linuxcnc.org/dists/lucid/scratc...ode~dafe9ea_i386.deb
- Michael
- Michael
10 Jan 2013 21:38 #28547
by mhaberler
the ferror-mode patch has been merged into v2.5_branch.
- Michael
- Michael
The following user(s) said Thank You: Todd Zuercher
- Topic Author
10 Jan 2013 22:23 #28549
Now hopefuly someday I will find the time to try it out. It won't happen in the near future.
Time to create page: 0.757 seconds
