(abort, MSG) in O-sub
- h_munktell
30 Dec 2012 21:44 - 30 Dec 2012 21:45 #28179
by h_munktell
(abort, MSG) in O-sub was created by h_munktell
Hello, maybe the wrong forum category, moderator can move thread if needed.
Ok, I have a Z touch off /probe routine:
This gets called from a GladeVCP button. If probing fails, the conditional else is executed, but I only get the abort message, not the safe Z retract movement. If I change the "abort" to "MSG", I first get the movement, and then the message.
But I would like to get more like a warning/error rather than the message icon thing.
Why does the abort message cancel code before it is called? Bug?
Regards
Henrik
Edit: I'm on newest Master
; this is called from gladevcp MDI action with the following
; MDI command:
; O<probe> call [${pfeed-f}] [${dist}] [${probeplate}] [${z_safe-f}]
O<probe> sub
M73 (Save modal state)
G49 (cancel dynamic tool length offset)
G91 (relative mode)
F #1 (Set feed)
G38.3 Z #2 (Probe towards workpiece)
o100 if [#5070 EQ 1] (Probe sucessfull)
(MSG, Probe successful!)
G10 L20 P[#5220] z[#3] (Set Z touch off point coordinate)
G0 Z [#4] (Retract Z)
o100 else (Probe failed)
G90 G53 G0 Z0 (Retract to safe Z)
(abort, Probe failed!)
o100 endif
O<probe> endsub
Regards
Henrik
Last edit: 30 Dec 2012 21:45 by h_munktell.
31 Dec 2012 00:12 #28185
by Rick G
You could try putting a pause after the movement and before the abort to give it time to complete.
Rick G
Replied by Rick G on topic (abort, MSG) in O-sub
Perhaps not, perhaps the movement is stopped by abort before it is completed.Why does the abort message cancel code before it is called? Bug?
Rick G
31 Dec 2012 00:44 #28188
by BigJohnT
Replied by BigJohnT on topic (abort, MSG) in O-sub
I don't see anything about there being an abort message, can you link the relevant part of the manual?
- h_munktell
31 Dec 2012 01:08 #28190
by h_munktell
Replied by h_munktell on topic (abort, MSG) in O-sub
Rick, the movements are not started at all, and they should be finished before executing the next line of program. I tried a G4 P5 inbetween the movement and the abort with no luck. When entering the else statement, the abort message is instantly displayed.
John, it's in the developer manual at: www.linuxcnc.org/docs/devel/html/remap/s...g_dealing_with_abort
G4 P5
o100 endif
31 Dec 2012 05:06 #28203
by BigJohnT
Thanks, need to read the developers manual more... could be as soon as the interpreter reads in the abort it happens. You might try nesting another if block with the abort message... just guessing out loud.
- h_munktell
31 Dec 2012 05:11 #28204
by h_munktell
Thanks, but already tried that, like this:
Same thing, which is extremely strange. If the code where to be compiled by a high level compiler, I could have understod that the second if statement would be optimized into the first. But to my knowlege this is a interpreter(?) language and that should not happen.
; MDI command:
O<probe> sub
G91 (relative mode)
F #1 (Set feed)
;(MSG, Probe successful!)
o100 endif
o110 if [#5070 EQ 0]
o110 endif
O<probe> endsub
31 Dec 2012 05:33 #28205
by BigJohnT
I was thinking of a nested if, say to test if Z is at 0 with 5422 or something like that after the G90 so it is only true when you get to Z0.
03 Jan 2013 20:41 #28344
One workaround might be to interleave a motion-synchronised command, such as an M67 or M62.
Replied by andypugh on topic (abort, MSG) in O-sub
I suspect that message printing happens in the user-space process, and is not added to the real-time queue.Same thing, which is extremely strange. If the code where to be compiled by a high level compiler, I could have understod that the second if statement would be optimized into the first. But to my knowlege this is a interpreter(?) language and that should not happen.
03 Jan 2013 21:11 #28345
by mhaberler
yes, forcing the interpreter queue to finish by a 'read pin' command should work
unfortunately the interpreter as it stands doesnt have a command to 'wait until queue executed up to here', but it would be relatively simple to add by a M- or G-code which returns INTERP_EXECUTE_FINISH
- Michael
Replied by mhaberler on topic (abort, MSG) in O-sub
- Michael
- h_munktell
04 Jan 2013 02:50 #28351
by h_munktell
Tried this, did not work, got no message from the while loop.
o101 do
(msg, In while)
G90 G53 G0 Z0
o101 while [#5422 LT 0]
o100 endif
Time to create page: 0.124 seconds
