(abort, MSG) in O-sub
- h_munktell
04 Jan 2013 02:55 #28352
by h_munktell
Thanks, but tried this, hope it was kind of this you thought of?, with no success:
Replied by h_munktell on topic (abort, MSG) in O-sub
I suspect that message printing happens in the user-space process, and is not added to the real-time queue.Same thing, which is extremely strange. If the code where to be compiled by a high level compiler, I could have understod that the second if statement would be optimized into the first. But to my knowlege this is a interpreter(?) language and that should not happen.
One workaround might be to interleave a motion-synchronised command, such as an M67 or M62.
o100 if [#5070 EQ 1] (Probe sucessfull)
(MSG, Probe successful!)
G10 L20 P[#5220] z[#3] (Set Z touch off point coordinate)
G0 Z [#4] (Retract Z)
o100 else (Probe failed)
G90 G53 G0 Z-1 (Retract to safe Z)
M62 P #<_ini[pins]probing> ; turn on probing led for testing purposes
G53 G0 Z0
(abort, Probe failed!)
o100 endif
04 Jan 2013 02:56 #28353
by mhaberler
Replied by mhaberler on topic (abort, MSG) in O-sub
yes, because the abort command causes a flush of the interpreter queue long before the execution even gets to the instruction before the abort
you _must_ use a 'queuebuster operation' before the abort which are tool change, input read, probe.
Reading a pin and ignoring the value is your best bet right now.
I'll look into faking a queue buster with remapping.
- Michael
- Michael
- h_munktell
04 Jan 2013 03:00 #28354
by h_munktell
Hi, thanks. Tried this and it works, now I only need to fin out the INTERP_EXECUTE_FINISH thing and write a own M code... :
yes, forcing the interpreter queue to finish by a 'read pin' command should work
unfortunately the interpreter as it stands doesnt have a command to 'wait until queue executed up to here', but it would be relatively simple to add by a M- or G-code which returns INTERP_EXECUTE_FINISH
- Michael
G90 G53 G0 Z0 (Retract to safe Z)
M66 P #<_ini[pins]changed> L1 Q#<_ini[dwell]ack_secs>
o100 endif
- h_munktell
04 Jan 2013 03:15 #28355
by h_munktell
Found the manual page for task and intr synch, INTERP_EXECUTE_FINISH etc:
www.linuxcnc.org/docs/devel/html/remap/s...mc_program_execution
Reading into it right now.
04 Jan 2013 05:21 #28357
by mhaberler
I added an example to master:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...7cfdebd9df8ec1e1c398
- Michael
- Michael
- h_munktell
04 Jan 2013 05:22 #28358
by h_munktell
Did not see your post before my last posts. I now understand the execution in interpreter and task, very helpfull, thanks! So, I do a bogus read as you said and it's working great. However, it would be nice to have a own defined M-code that had the 'queuebuster operation' .
- Michael
; this is called from gladevcp MDI action with the following
; MDI command:
; O<probe> call [${pfeed-f}] [${dist}] [${probeplate}] [${z_safe-f}]
O<probe> sub
M73 (Save modal state)
G49 (cancel dynamic tool length offset)
G91 (relative mode)
F #1 (Set feed)
G38.3 Z #2 (Probe towards workpiece)
M66 P0 L0 ;Bogus read, need to have a "queuebuster" here to synch task and interpreter
o100 endif
O<probe> endsub
04 Jan 2013 05:26 #28359
by mhaberler
changing the G-code into an M-code is left as an exercise for the reader
-m
-m
The following user(s) said Thank You: h_munktell
- h_munktell
04 Jan 2013 05:35 #28360
by h_munktell
Again, forum post race condition Checked the new example and implemented G70, works like a treat Will look into to change to M-code (without help, documentation is sure enough )
ps. Note to forum admin, would be nice to have a function that notice you when hitting post if there is new messages posted after you started to write your post
04 Jan 2013 06:17 #28361
by BigJohnT
Replied by BigJohnT on topic (abort, MSG) in O-sub
That's only available in pay forum software I assume... you should have seen what we had before!
Time to create page: 0.152 seconds
