Spindle orientation
22 Jan 2013 02:00 #28927 by tld70
Spindle orientation was created by tld70
Hi Guys
is there a way to orient the Spindle by HAL or COMP
included the angle in degrees
some times ago I read something about loadrt orient.....
But this dont work.
Hope you can help me
Thomas
22 Jan 2013 07:52 - 22 Jan 2013 07:54 #28936 by BigJohnT
Replied by BigJohnT on topic Spindle orientation
There might be more to just loading the orient component. The manual page is here and it includes example HAL lines for usage. I was pleasantly surprised to find the orient component as I will need that when I convert my Discovery 308.
Last edit: 22 Jan 2013 07:54 by BigJohnT.
22 Jan 2013 14:50 #28939 by tld70
Replied by tld70 on topic Spindle orientation
Good morning
this is exactly what I found,
but it dont work.
The Error is " Can't find module 'orient'....
Do I have to install something?
22 Jan 2013 17:36 - 22 Jan 2013 17:37 #28949 by ArcEye
Replied by ArcEye on topic Spindle orientation
JT
Does not seem to be in the .deb or the source for 2.5.1, despite being in the docs.
It is however in the master. :huh:
tld70
The attached zip contains the orient.comp and a compiled module built against Linuxcnc 2.5.1 running on 10.04
It goes in /usr/realtime-xxxxxxxx/modules/linuxcnc
then run sudo /sbin/depmod -a to make sure it is found
If that flavour does not match yours, instructions for compiling below
linuxcnc.org/docs/2.5/html/hal/comp.html
File Name: orient.zip
File Size:42 KB
Last edit: 22 Jan 2013 17:37 by ArcEye.
22 Jan 2013 18:58 #28953 by tld70
Hello,
do I need more?
it dont runs
net orient-angle motion.spindle-orient-angle orient.angle
net orient-mode motion.spindle-orient-mode orient.mode
linuxcnc says the pin motion.spindle-orient-angle is not found...
22 Jan 2013 20:24 #28959 by ArcEye
OK
Mystery solved, the reason the module is not in 2.5.1, despite the docs being there, is that motion.spindle-orient-????? pins only exist in 2.6
If you really need this module you will have to download and run the master (2.6)
Regards the iocontrol module, the one I wrote for you will not work as is, but I don't think the changes in the master go much beyond someone messing about with it and changing uppercase constants to lowercase ones.
I need to look at it for someone else anyway, so will get back to you in the next few days.
22 Jan 2013 20:54 #28962 by ArcEye
See your original spindle thread for the updated ioControl file.
22 Jan 2013 21:28 - 22 Jan 2013 21:45 #28967 by BigJohnT
JT
There seems to be some kind of snafu with the online docs as it is not in my local built docs. And all that time I thought someone slipped that in when I wasn't looking. It's actually not in the local docs only the online docs as well as bldc_sine.9.
Last edit: 22 Jan 2013 21:45 by BigJohnT.
02 Feb 2013 21:28 #29489 by tld70
Hello,
today I try the orien comp.
Bus the Spindle does nothing,
ans in the description orient is thie line:
net spindle-pos ...encoder..position orient.position orient-pid.position
But linuxcnc dont know the pin pid.4.position ( I use pid4 because I need 4 PIDs )
motion.spindle-orient is 1
orient.enable is 1
orient.poserreo is 249.
What I do wrong?
02 Feb 2013 23:11 #29496 by ArcEye
You will have to post your hal file, or at least the relevant part of it, for us to be able to help much.
Only thing that jumps out, is that pid.4 would be the 5th pid not the 4th, because numbering starts at 0
Time to create page: 0.069 seconds
