Compiling probekins and using probe2stl
- alan_3301
- Thank you received: 33
22 Apr 2013 16:14 - 22 Apr 2013 16:15 #32984
by alan_3301
Replied by alan_3301 on topic Compiling probekins and using probe2stl
Can you just move the tool down 3-4mm and touch off Z to 0?
That was step 11 on my list.
11. touch off X and Y if necessary and touch off Z
Also make sure that Z is adjusting the correct direction. I had problems with that before.
It's good you are making progress. It should all be working soon.
Last edit: 22 Apr 2013 16:15 by alan_3301.
- slacker247
23 Apr 2013 00:21 - 23 Apr 2013 00:24 #33011
by slacker247
Replied by slacker247 on topic Compiling probekins and using probe2stl
I tried doing touch off to and initially thought that was why it was hovering. The coords in the 3d view are saying that z = -0.2 and when I stop it and do G1 Z0, it does not touch the surface, it just moves up slightly and right before I hit play I did a touch off. to get it to touch the surface I have to move it to -1.223 z. so somewhere it is moving it up for some reason.
when I turn on z correct I get "joint 2 following error". I'm not sure how I look at the actual error. But I assume that it is just because the cut path is out side the z correct field.
I just got a "joint 1 following error" when I issued the command G1 X0 Y0. it turned "off the machine" so I clicked the power button and issued the command again and it successfully moved to 0,0.
I think it might be time to look at the code. I hate looking at other peoples code....
Last edit: 23 Apr 2013 00:24 by slacker247.
- alan_3301
23 Apr 2013 02:07 #33019
by alan_3301
Are you probing in the same units as running the program? G20 or G21
Have you looked at the files I posted earlier? In the probing routing, I added a few LOGs to add the machine outer bounds to the probe file.
That will help cure following errors when moving outside the probed area.
If you get a following error when you turn on z correction, then the delta-z is too far from 0. It tries to jump into position, but isn't quick enough.
That is the reason you need to be in the XY position where you touch off Z to 0. It won't try to move the Z, because delta-z should = 0.
A joint 1 following error, I don't think would be related to probekins, as it should only adjust Z.
- coppermage
20 May 2014 10:15 #47074
by coppermage
Replied by coppermage on topic Compiling probekins and using probe2stl
I'm trying to make the probekins module work, and am having trouble with stlcorr not getting the shared memory segment.
I've checked out the development branch of linuxcnc (2.7.0~pre0), and added the probekins code, and succesfully compiled it.
Using the example 'sim/axis/axis' configuration, I've replaced 'loadrt trivkins' with 'loadrt probekins size=2048' in core_sim.hal.
using the 'rip' environment, linuxcnc comes up, and log messages from dmesg indicate that probekins is loaded correctly, and
allocated shared memory as expected:
[ 3421.457981] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 3421.458009] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 3421.458037] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3421.458062] PIPELINE layers:
[ 3421.458087] f91dae20 9ac15d93 RTAI 200
[ 3421.458110] c085cb20 0 Linux 100
[ 3421.485171] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3421.485302] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 3421.485315] RTAI[sched]: hard timer type/freq = APIC/62162364(Hz); default timing: periodic; linear timed lists.
[ 3421.485319] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2090963000 hz.
[ 3421.485321] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3421.485396] RTAI[usi]: enabled.
[ 3421.573041] RTAI[math]: loaded.
[ 3421.669349] HAL: initializing component 'probekins'
[ 3421.669354] RTAPI: initing module HAL_probekins
[ 3421.669363] RTAPI: module 'HAL_probekins' loaded, ID: 8
[ 3421.669368] HAL: component 'probekins' initialized, ID = 08
[ 3421.669371] probekins debug=0 shmsize=2048 comp_id=8
[ 3421.669410] RTAPI: shmem 02 created by module 08, key: 4711, size: 2048
[ 3421.669412] faces offset=80
[ 3421.669415] HAL: creating pin 'probekins.enable-z-correct'
[ 3421.669432] HAL: creating pin 'probekins.delta-z'
[ 3421.669436] HAL: creating pin 'probekins.flags'
[ 3421.669440] HAL: exporting function 'pkupdate'
[ 3421.669443] HAL: creating parameter 'pkupdate.time'
[ 3421.669446] HAL: creating parameter 'pkupdate.tmax'
[ 3421.911314]
However, when I try to load shared memory with 'stlcorr.py --load <probe.stl', I get the following error:
File "./stlcorr.py", line 171, in <module>
main()
File "stlcorr.py", line 130, in main
load_file(b,filename)
File "stlcorr.py", line 62, ln load_file
raise Exception "Buffer too small, have %d need %d" %(len(b),req)
Exception: Buffer too small, have 0 need 164
The problem appears to be that getbuffer does not return "anything" (I'm not enough of a python programmer to be more specific)...
I added some print statements to the get_buffer routine in stlcorr.py, and get the following:
c is <hal component notused(20) with 0 pins and params>
sm is <shared memory buffer key=1267 id=2 size=0>
The 1267 is the hex representation of 4711, which is the 'key' value coded into probekins, and the argument to the hal.shm call.
Sooo.... any ideas?
Thanks in advance!
*** Doug
[ 3421.911314]
main()
Sooo.... any ideas?
Thanks in advance!
*** Doug
- Thank you received: 4994
21 May 2014 06:16 #47122
Replied by andypugh on topic Compiling probekins and using probe2stl
Is stlcor _definitely_ loading after probekins?
You might try putting the loadusr for stlcor in the postgui HAL just to be sure.
- coppermage
21 May 2014 09:27 #47135
by coppermage
Yes, I'm sure - I'm running stlcorr as a seprate command manually after linuxcnc is up-and-running.
However, I did try the postgui trick (just in case), and got exactly the same error messages.
*** Doug F.
*** Doug F.
21 May 2014 14:58 #47142
My next thought is that perhaps the buffer keys are both decimal (or both hex).
Do you get to choose either of them?
- alan_3301
21 May 2014 17:24 #47150
by alan_3301
what is on line 11 of the file stlcorr?
size = 2048? or something else?
It needs to match the number you specify when you load probekins module.
- coppermage
21 May 2014 19:59 #47155
by coppermage
No, they are identical...
- coppermage
21 May 2014 20:15 #47157
by coppermage
Bingo! That was the issue.
It appears to be working now.
For future generations,Here is the specific change:
In the function get_buffer() in stlcorr.py:
was:
sm = hal.shm(c,key,0)
new:
sm = hal.shm(c,key,2048)
(2048 is the argument for buffer size that I used when loading probekins in the hal file)
I think the theory in the original code was that the call to hal.shm would supply the size of the shared memory
buffer. Obviouosly (now) that isn't true....
THANKS alan_3301 (and andypugh, too) for your help. Now I can move on to using probekins.
*** Doug
was:
new:
*** Doug
Time to create page: 0.093 seconds
