Dual X Servo
- juwi
28 Apr 2013 05:23 #33300
by juwi
Dual X Servo was created by juwi
Hi
www.linuxcnc.org/index.php/english/forum...in-closed-loop#23714
Andy told me "simply" to:
"connect axis.1.motor-pos-cmd to both PID modules in the HAL"
How is this done? If I just change:
net a-pos-cmd axis.3.motor-pos-cmd
to
net a-pos-cmd axis.1.motor-pos-cmd
There comes an "net already connected" error on Startup...
HAL File is attached, INI too, A axis is second Y axis
Help?
best regards
to
Help?
best regards
- juwi
28 Apr 2013 05:52 - 28 Apr 2013 05:52 #33301
by juwi
Replied by juwi on topic Dual X Servo
michas_kleine.hal:164: Signal 'y-pos-cmd' can not add OUT pin 'axis.3.motor-pos-cmd', it already has OUT pin 'axis.1.motor-pos-cmd'
Last edit: 28 Apr 2013 05:52 by juwi.
- Thank you received: 5017
28 Apr 2013 07:27 #33308
I just tried to make your HAL file work as suggested, and I have realised that it is rather important to know if you intend to use index-homing on both sides of the gantry.
I think I need to have a good long think about how to do homing on a gantry axis that uses servos and trivkins.
Replied by andypugh on topic Dual X Servo
Hi
How is this done?
28 Apr 2013 07:30 #33309
This is the HAL file I came up with, but I can't really test it.
The main point is that the HAL is now assuming a 3-axis machine, but with 4 PID controllers and 4 motors to drive.
The following user(s) said Thank You: juwi
- juwi
28 Apr 2013 07:53 #33311
by juwi
michas_kleine.hal:111: Pin 'axis.0.motor-pos-cmd' was already linked to signal 'x1-pos-cmd'
exactly my problem...
- juwi
28 Apr 2013 08:25 #33312
by juwi
Homing is almost irrelevant, because I can home the machine by hand - its quite small - or by a special homing config with gantrykins...
My Problem is that hal forbids to add more than one outs to a net...
best regards
Hi
How is this done?
best regards
28 Apr 2013 19:03 #33323
Yes, only one of the pins in the net can be an output (such as axis.0.motor-pos-cmd). This is logical, as otherwise the value of the net is ambiguous.
To use one output to drive multiple inputs you can use any of the following structures.
net x-pos axis.0.motor-pos-cmd => pid.0.command pid.1.command
or
net x-pos axis.0.motor-pos-cmd=> pid.0.command
net x-pos pid.1.command
or
net x-pos pid.0.command
So, each signal (the label directly after the "net" command) can have only one output pin connected, but can have as many input pins as you need.
- juwi
28 Apr 2013 19:07 #33324
by juwi
This works, but leads to a following error on the slave axis after exceeding max-ferror...
28 Apr 2013 19:12 #33325
If the motors point in different directions then you will need a negative encoder scale on one of them.
Each PID component needs to be connected to the same command position pin, but to its own feedback position pin.
- juwi
28 Apr 2013 19:26 #33327
by juwi
I write on my mobile, therefore short...
I left everything of the slave axis as it was, just connect the pid.commanded from y.pos to both. Result is following error after exceeding fferror-max.
Both are setup identical and rotate in the same direction...
