Dual X Servo
- juwi
30 Apr 2013 20:09 #33438
by juwi
Replied by juwi on topic Dual X Servo
Solution in a short:
1. remove ALL axis.x.?????????? from the slave axis
2. set pid.SLAVE.commanded from the master axis
3. add a diff2 for the maximum slave / master axis position difference and make the result to estop
4. add the possibility to reset both encoders, because the slave encoder is filled with random data every reboot.
ist is not that simple, but working now. I'll upload my config her later.
best regards
best regards
- Thank you received: 5270
30 Apr 2013 21:30 - 30 Apr 2013 21:44 #33447
Are you saying one encoder position is not cleared when launching LinuxCNC?
If so this is a bug. AFAIK and in my experience, all encoders are cleared at linuxcnc startup
(That is will all read 0 at whatever random position the machine was left in)
Replied by PCW on topic Dual X Servo
Last edit: 30 Apr 2013 21:44 by PCW.
- juwi
30 Apr 2013 22:35 #33452
by juwi
hm2_5i25.0.encoder.02.position and hm2_5i25.0.encoder.01.position differ randomly after each restart.
some mor info -> Topic:
__________________________________________________________________________________
gantry-ferror:
#load near function
loadrt near
#add to thread
addf near.0 servo-thread
#y1-pos-fb is hm2_5i25.0.encoder.01.position
net y1-pos-fb near.0.in1
#y2-pos-fb is hm2_5i25.0.encoder.02.position
net y2-pos-fb near.0.in2
#permit 0.1 machineunits sheering
setp near.0.difference 0.10
net ferror-gantry <= near.0.out
encoder reset:
net reset_y_encoder gladevcp.hal_button1
net reset_y_encoder hm2_5i25.0.encoder.01.reset
net reset_y_encoder hm2_5i25.0.encoder.02.reset
gantry-ferror:
#load near function
loadrt near
#add to thread
encoder reset:
30 Apr 2013 22:42 #33454
I can see that they may have a small error until homed
Do you see a difference in the encoder positions after startup and estop cleared (before drives are enabled)? this would be a bug.
Time to create page: 0.055 seconds
