arduino display
- billykid
- Thank you received: 80
16 Aug 2013 00:35 #37716
by billykid
arduino display was created by billykid
I have seen the excellent work of Arceye (arduino pendant) and let me know if you have the code for display only xyza position
Mauro
Mauro
- ArcEye
- Thank you received: 758
16 Aug 2013 15:46 #37732
by ArcEye
Replied by ArcEye on topic arduino display
Hi
It would be pretty trivial to add an extra axis to the component and arduino script.
Just copy the code for Z axis and change everything to relate to A axis.
It will need to display on the bottom line of the LCD, so look at where JOG OFF displays (see 'R' command), comment that out and use the location for A axis
Even if you are not quite sure how it all works, you will learn a lot more experimenting with the code, than by my changing it for you.
Give it a go
Give it a go
- billykid
16 Aug 2013 17:10 #37735
by billykid
Replied by billykid on topic arduino display
I will get to work
I really tried to compile the part for arduino but gives me errors.
maybe because I did copy paste on your site?
Mauro
Mauro
- ArcEye
16 Aug 2013 17:36 #37736
by ArcEye
I have attached the code to the original topic
It is available here www.linuxcnc.org/media/kunena/attachments/1749/arduino.zip
- billykid
16 Aug 2013 18:44 #37738
by billykid
ok
I tried to compile from just a mistake ..
key.h not found
only one
Mauro
key.h not found
only one
Mauro
- ArcEye
16 Aug 2013 19:03 #37740
by ArcEye
If in doubt, RTFT
www.linuxcnc.org/index.php/english/forum...pendant-for-linuxcnc
its the 4th post down
The following user(s) said Thank You: billykid
- billykid
17 Aug 2013 02:11 #37763
by billykid
well .. compiled without errors
I try the display as soon as possible.
thanks for help
Mauro
thanks for help
Mauro
- billykid
18 Aug 2013 17:08 #37802
by billykid
Hi
sudo comp --install --userspace --serialcon.comp
sudo: comp: command not found
linuxcnc 2.5.3
apt sources linuxcnc.org lucid base linuxcnc 2.5
linuxcnc.org lucid base linuxcnc 2.5 (source code)
can you tell me what's wrong?
Mauro
linuxcnc 2.5.3
Mauro
- ArcEye
18 Aug 2013 17:54 #37805
by ArcEye
apt-get install linuxcnc-dev
That is where comp is from
- billykid
18 Aug 2013 19:39 #37810
by billykid
ok installed... but "sudo comp --install --userspace --serialcon.comp" isn't the exactly command...
Mauro
Mauro
