arduino display
- ArcEye
- Thank you received: 758
18 Aug 2013 20:33 #37811
by ArcEye
--install and --userspace are commandline switches to comp
The component is called serialcon.comp,
sudo comp --install --userspace serialcon.comp
Replied by ArcEye on topic arduino display
ok installed... but "sudo comp --install --userspace --serialcon.comp" isn't the exactly command...
Mauro
- billykid
- Thank you received: 80
19 Aug 2013 00:55 - 19 Aug 2013 02:17 #37816
by billykid
Replied by billykid on topic arduino display
I'm mortified ... I put in serialcon.comp usr / src but is not seen.
you know the exact path on ubuntu lucid?
thanks for your patience
Mauro
solved
compiled outside source tree
Mauro
solved
Last edit: 19 Aug 2013 02:17 by billykid. Reason: solved
- billykid
19 Aug 2013 20:02 #37849
by billykid
hi
I found this serial display cubloc.com/display/CVFD.pdf but I can not make it work.
will be incompatible or my arduino revision 2 is incompatible?
I'm trying with the library liquidcrystal serial.
Mauro
Mauro
- ArcEye
19 Aug 2013 20:46 - 19 Aug 2013 20:47 #37851
by ArcEye
You will have to look up the docs for the LiquidCrystal library
I just used a standard LCD with an i2c back pack
If yours has i2c already on it it should work, but I only know about the the one I used, sorry
Last edit: 19 Aug 2013 20:47 by ArcEye.
- billykid
19 Aug 2013 23:37 #37855
by billykid
I had this lcd + back pack CuNET (i2c) for cublock but displays random characters.
I ordered the correct display for arduino i2c.
I would like to know which usb port to use then with LinuxCNC, or if you need to set some addresses
Mauro
Mauro
- ArcEye
20 Aug 2013 00:16 #37856
by ArcEye
Depends upon which arduino board you use as to which port it uses
serialcon.comp sets it as below, you may have to change it if that is not the port yours uses
#define DEVICE "/dev/ttyUSB0"
The following user(s) said Thank You: billykid
- billykid
20 Aug 2013 04:01 #37864
by billykid
good! dev/ttyUSB0 but the port needs to be root to open?
Mauro
Mauro
- ArcEye
20 Aug 2013 15:44 #37874
by ArcEye
You need to sort out your udev rules and make yourself a member of plugdev or whatever group have rights to read/write to them
usbpicprog.org/?page_id=13
www.linuxquestions.org/questions/slackwa...lar-usb-port-621291/
google again if these don't cover it
- billykid
23 Aug 2013 02:51 #37978
by billykid
hi
Display is working, tested with examples.
I had to use the library for liquidcrystal_i2c PCF8574A mounted on my display.
I programmed Arduino without errors, serialcon is running, i am a member of plugdev.
if you can give me a hal file as an example for understanding the operation ..
Mauro
Mauro
- ArcEye
23 Aug 2013 13:50 #37985
by ArcEye
First page of the thread
