Linear scale correction: homing to index
15 May 2014 04:43 #46947 by PCW
Hmm if that were the case this would affect everyone that homes to index and that is not the case AFAIK
I would try a minimal home to index case in master
15 May 2014 10:43 #46953 by Todd Zuercher
Replied by Todd Zuercher on topic Linear scale correction: homing to index
i seem to have this problem as well. For some reason it only seems to affect one of my 4 axis when homing. After the following error alarm is cleared it usually homes fine the second time. It only seems to do it on the first attempt at homing after starting linuxcnc.
15 May 2014 11:40 #46954 by PCW
What version of linuxcnc do you have? (exact version is important)
A problem on only one axis suggests a hal file error, can you post you hal and ini files here?
15 May 2014 14:23 #46956 by DaBit
Replied by DaBit on topic Linear scale correction: homing to index
Sounds exactly the same like my situation, although I currently have only one servo axis running. I also have to restart LinuxCNC to be able to catch the following error again. Once the f-error happened I can unhome and rehome as much as I want without following errors.
But of course the position counters don't step-change anymore during the rest of the session since it will be reset when it is already at 0.
So, what LinuxCNC version do you suggest for further testing? Fresh GIT pull from master? Or one of the stable releases?
15 May 2014 19:42 #46960 by Todd Zuercher
I am using 2.5.4, and I also had the same problem when I was testing the new trajectory planner version of master (that was a few months ago).
I've just been living with it
I can post my config if it might help.
15 May 2014 20:44 #46962 by PCW
I would suggest using master (especially if you use error last target)
posting hal an ini files would help
15 May 2014 22:34 #46964 by Todd Zuercher
Here it is.
15 May 2014 23:01 #46965 by PCW
I dont see anything obvious wrong in the hal file
I would try removing all the unused
net N-pos-rawcounts <= hm2_5i25.0.encoder.0N.rawcounts
lines as I have seen issues with this in other systems
What axis has the problem?
15 May 2014 23:23 - 15 May 2014 23:32 #46967 by Todd Zuercher
Usually just the X, but once in a while Y also.
Commenting out net N-pos-rawcounts <= hm2_5i25.0.encoder.0N.rawcounts didn't make any difference.
Last edit: 15 May 2014 23:32 by Todd Zuercher.
16 May 2014 21:16 #46981 by PCW
I spent a couple of hours testing homing to index yesterday (with master)
and cannot find any issues.
Can you plot
axis.0.motor-pos-cmd
axis.0.motor-pos-fb
axis.0.ferror
axis.0.index-enable
pid.0.out
with halscope?
halscope should be triggered on the falling edge of index enable
while doing a home sequence. This would help isolate the problem.
This needs a fast sweep, say 1 ms/division and the falling edge of index
enable visible on the screen, and normal, not auto mode trigger mode.
Time to create page: 0.076 seconds
