c++ grab in position signal
30 Aug 2014 18:03 - 30 Aug 2014 21:24 #50512 by ArcEye
Replied by ArcEye on topic c++ grab in position signal
Should be quite simple.
Just read the whole file into memory, an array of char buff[80] say, allocated dynamically according to the size of the file, then you can just read it with an incrementing index.
If you have different files for different positions, just means multi-dimensional arrays, one index for the physical position and another for the position in the file for that place.
Mine was just a very simple example, to show that feeding lines through a component worked.
Last edit: 30 Aug 2014 21:24 by ArcEye.
The following user(s) said Thank You: bkt
30 Aug 2014 21:27 #50520 by ArcEye
This is a simple example of what I mean, using the previous example as the basis.
It is just using a single dimemsional array of char* each holding a line from the file.
It compiles, but I haven't had time to test it
component mdipump2                     "This component reads a file and pushes MDI commands to Linuxcnc";
pin in bit commandfinished = 0        "signal last command completed - connect to motion.in-position";
pin in bit homed = 0                  "signal that machine is homed and ready for commands - connect to last axis to home - halui.joint.2.is-homed";
pin in bit machineon = 0              "signal to ensure machine is on - connect to halui.machine.is-on";
option singleton yes;
option userspace yes;
author "ArcEye <arceyeATmgwareDOTcoDOTuk>";
license "GPL";
#include <stdio.h>    /* Standard input/output definitions */
#include <stdlib.h>
#include <stdint.h>   /* Standard types */
#include <string.h>   /* String function definitions */
#include <unistd.h>   /* UNIX standard function definitions */
#include <fcntl.h>    /* File control definitions */
#include <errno.h>    /* Error number definitions */
#include <signal.h>
#include <pwd.h>
int done = 0;
void adios(int sig) { done = 1; }
void user_mainloop(void)
char filepath[80];
int progress = 0;
char line[80];
char cmdline[80];
char *linearray[20];  // max 20 lines to keep it simple
char *lineptr;
    // get user home dir
struct passwd *pw = getpwuid(getuid());
const char *homedir = pw->pw_dir;
sprintf(filepath, "%s/linuxcnc/gcode.ngc", homedir);
FILE *fp1;
fp1 = fopen(filepath, "r");
int arraylen = 0, arrayindex = 0;
while(!feof(fp1))
    fgets(line, sizeof(line), fp1);
    lineptr = (char *)malloc(sizeof(line) + 1);
    memcpy(lineptr, line, sizeof(line));
    linearray[arraylen++] = lineptr;
signal(SIGINT, adios);
signal(SIGTERM, adios);
    while(!done)
        usleep(250000);
        FOR_ALL_INSTS()
            if(homed && machineon)
                switch(progress)
                    case 0:
                            if(arrayindex <= arraylen)
                                memcpy(line, linearray[arrayindex], sizeof(linearray[arrayindex]));
                                arrayindex++;
                                fprintf(stderr,"Line:- %s ", line);// debug
                                sprintf(cmdline, "axis-remote --mdi '%s'", line);
                                system(cmdline);
                                progress = 1;
                                break;
                            else
                                done = 1;
                                fprintf(stderr,"Output completed");
                                break;
                    case 1: if(!commandfinished)
                                break;
                            else
                                progress = 0;
                    default:
                            break;
    exit(0);
01 Sep 2014 23:28 #50583 by andypugh
Replied by andypugh on topic c++ grab in position signal
the idea of ​​reading an external file to mycomponent.comp is very good but does not work in my case.
In fact in my case I write only one xyz position at a time.
This means that at each new location, the system waits the time of writing and reading of the pc. This generates a time when the axes are still waiting for a new command.
I need a lot lower this time.
It is possible that you don't want to use the G-code interpreter at all.
A userspace component that calculates axis positions can command axis moves directly.
But even that might be too high-level. It is perfectly possible to pass axis positions directly to stepgen (for example) and just have the motors go there. The internal acell and velocity limits mean that stepgen is itself a very simple motion planner for one axis at a time.
If your code is calculating positions on the fly, then outputting those positions directly to HAL can work.
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Sep 2014 20:17 #50685 by bkt
Replied by bkt on topic c++ grab in position signal
sorry for late reply .... but I have my holiday.
to in an attempt to follow the ideas that came from the suggestions of ArkEye ... I mek this code on new mycomp
#ifdef RTAPI
#define _POSIX_C_SOURCE
#include "rtapi_math.h"
#include "rtapi.h"		/* RTAPI realtime OS API */
#include "rtapi_app.h"		/* RTAPI realtime module decls */
#include "hal.h"
#include <linux/unistd.h>
#include <linux/posix_types.h>
#include <linux/types.h>
#include <linux/signal.h>
void myMDIrow ( int idp){
    idp = 3012;
    if (*(haldata->sig1)) {kill(idp, SIGUSR1);}
    /*return */
#endif
this is incomplete and put the pid of my applycation manually now ... it's only a test ..... I grab motion.in-position signal by hal and transform it in to UNIX signal USR1 ... In my QT application I use this signal to generate new mdi row with xyz pos and send it to linuxcnc ..... every new motion.in-position send a new mdi row ....
Unfortunately, I have this error during compilation:
error: implicit declaration of function ‘kill’
I don't Know how to solve this ....
-D_POSIX_C_SOURCE
flag is not a solution ... I need some suggestion ....
@ andypugh ..... thanks ... But eventually I should send positions found directly to mydeltakins-withlimitfunc.comp .... I think is possible pass the position to hal and than to mydeltakins-withlimitfunc.comp but how to? .... how to send new position to hal from qt program? Is possible to comunicate with deltakins.comp whit a standard C/C++ pipe?
03 Sep 2014 22:37 #50691 by ArcEye
Hi
kill() seems to be one system command that varies from system to system and kernel version to version
This is a simple program adapted from the GNU examples which builds and runs on Wheezy 3.2.0-4-rt-amd64
You don't need <sys/posix_types.h> just these headers and don't have to set _POSIX_C_SOURCE
#include <stdlib.h>
     #include <signal.h>
     #include <stdio.h>
     #include <sys/types.h>
     #include <unistd.h>
     /* When a SIGUSR1 signal arrives, set this variable. */
     volatile sig_atomic_t usr_interrupt = 0;
     void
     synch_signal (int sig)
       usr_interrupt = 1;
     /* The child process executes this function. */
     void
     child_function (void)
       /* Perform initialization. */
       printf ("I'm here!!!  My pid is %d.\n", (int) getpid ());
       /* Let parent know you're done. */
       kill (getppid (), SIGUSR1);
       /* Continue with execution. */
       puts ("Bye, now....");
       exit (0);
     int
     main (void)
       struct sigaction usr_action;
       sigset_t block_mask;
       pid_t child_id;
       /* Establish the signal handler. */
       sigfillset (&block_mask);
       usr_action.sa_handler = synch_signal;
       usr_action.sa_mask = block_mask;
       usr_action.sa_flags = 0;
       sigaction (SIGUSR1, &usr_action, NULL);
       /* Create the child process. */
       child_id = fork ();
       if (child_id == 0)
         child_function ();          /* Does not return. */
       /* Busy wait for the child to send a signal. */
       while (!usr_interrupt)
       /* Now continue execution. */
       puts ("That's all, folks!");
       return 0;
Be aware that after kernels 2.6.38 ish, the headers started to be moved around
Both Wheezy and Ubuntu 12.04 have a directory called /usr/include/x86_64_linux_gnu (or i386_linux_gnu depending upon system type)
This directory contains /sys /bits /asm etc
I always symlink the contents back to the parent directory or a lot of older code will not build.
  • bkt
  • Platinum Member
  • Platinum Member
04 Sep 2014 22:25 - 04 Sep 2014 22:51 #50766 by bkt
First - I use ubuntu 10.04.... second - Sorry but I have some real problem with my idea .... I create a new myUNIXsignal-sender.c and I install it with:
sudo comp --install '/home/k1/linuxcnc/myUNIXsignal-sender.c'
The code that I use is only for testing ..... I don't now if is correctly written ... i Think is only a botched ..... but I use it for some experiments ....
/*#define _POSIX_C_SOURCE*/
/*#include "kinematics.h"*/             /* these decls */
#include "hal.h"
/*#include "stdint.h"
#include "stdlib.h"
#include "fcntl.h"
#include "string.h"
#include "sys/types.h"
#include "signal.h"
#include "stdio.h"
#include "unistd.h"*/
/*#include </usr/include/stdio.h>
#include </usr/include/stdlib.h>
#include </usr/include/stdint.h>   */
#include "stdlib.h"*/
/*#include "linux/fcntl.h"
#include "linux/string.h"
#include <linux/fcntl.h>
#include <linux/errno.h>
#include "linux/signal.h"*/
/*#include "fcntl.h"
#include "string.h"
#include "unistd.h"
#include "fcntl.h"
#include "errno.h"
#include "stdio.h"
/*#include "signal.h"*/
struct haldata {  hal_bit_t *sig1, *sig2;
} *haldata = 0;
#define delta_sig1 (*(haldata->sig1))
#define delta_sig2 (*(haldata->sig2))
#ifdef RTAPI
#include "hal.h"
#include "string.h"
#include "unistd.h"
#include "fcntl.h"
#include "errno.h"
#include "stdio.h"
#include "unistd.h"
#include "stdlib.h"
#include "fcntl.h"
#include "string.h"
#include "signal.h"
#include "stdio.h"
int kill (int pdi, int s){  kill(15962, SIGUSR1); return 0;}
int myMDIrow ( int idp, int sig){
    int pdi, s;
    idp = 15962;
    pdi = idp;
    sig = SIGUSR1;
    s = sig;
    if (*(haldata->sig1)) {kill(pdi, s);}
    return 0;
#endif
#ifdef RTAPI
#include "hal.h"
#include "stdlib.h"
#include "fcntl.h"
#include "string.h"
#include "signal.h"
#include "stdio.h"
/* module information */
MODULE_AUTHOR("GFX");
MODULE_DESCRIPTION("Send UNIX signal from HAL");
EXPORT_SYMBOL(myMDIrow);
MODULE_LICENSE("GPL");
int comp_id;
int rtapi_app_main(void) {
    int res = 0;
    comp_id = hal_init("myUNIXsignal-sender");
    if(comp_id < 0) return comp_id;
    haldata = hal_malloc(sizeof(struct haldata));
    if(!haldata) goto error;
    if((res = hal_pin_bit_new("myUNIXsignal-sender.sig1", HAL_IN, &(haldata->sig1),comp_id)) != 0) goto error;
    if((res = hal_pin_bit_new("myUNIXsignal-sender.sig2", HAL_IN, &(haldata->sig2),comp_id)) != 0) goto error;
    hal_ready(comp_id);
    return 0;
error:
    hal_exit(comp_id);
    return res;
void rtapi_app_exit(void) { hal_exit(comp_id); }
#endif
Is you see I find in every way to correctly compile whit signal.h and other library .... but I receive only compile error .... I make various symlink in my system for correctly cath the system library .... but linuxcnc don't accept it .... than I use only hal.h etc and I hope that "kill" function is bring .... but I have no result.
My QT program is created for bring UNIX signal ... if test it from terminal I can correctly use " kill -SIGUSR1 qtpgrPID" .... My QT program bringh correctly this signal and send correctly to linuxcnc/axis a new line similar to this:
command = "axis-remote --mdi ' G1  F100000 X100 Y100 Z-800'";
                  system(command.toStdString().c_str());
In myUNIXsignal-sender.c I would like to send a kill signal whenever I get a bit from hal (motion.in-position or position axis.1.in-bit).
Actually the major problem is probabily the symlink ... I have create symlink .... for example locate signal.h have this output:
/home/k1/qt-everywhere-opensource-src-4.8.6/doc/html/declarative-cppextensions-referenceexamples-signal.html
/home/k1/qt-everywhere-opensource-src-4.8.6/doc/html/q3signal.html
/home/k1/qt-everywhere-opensource-src-4.8.6/include/Qt/q3signal.h
/home/k1/qt-everywhere-opensource-src-4.8.6/include/Qt3Support/q3signal.h
/home/k1/qt-everywhere-opensource-src-4.8.6/src/qt3support/tools/q3signal.h
/usr/include/signal.h <----------------------------------- this not work if put it (signal.h) in my comp heather
/usr/include/asm/signal.h
/usr/include/asm-generic/signal.h
/usr/include/boost/signal.hpp
/usr/include/boost/signals2/preprocessed_signal.hpp
/usr/include/boost/signals2/signal.hpp
/usr/include/boost/signals2/variadic_signal.hpp
/usr/include/glib-2.0/gobject/gsignal.h
/usr/include/gtk-2.0/gtk/gtksignal.h
/usr/include/linux/signal.h
/usr/include/linuxcnc/signal.h   <------------ I have create This
/usr/include/pulse/mainloop-signal.h
/usr/include/qt4/Qt/q3signal.h
/usr/include/qt4/Qt3Support/q3signal.h
/usr/include/sys/signal.h
/usr/local/Trolltech/Qt-4.8.6/doc/html/declarative-cppextensions-referenceexamples-signal.html
/usr/local/Trolltech/Qt-4.8.6/doc/html/q3signal.html
/usr/local/Trolltech/Qt-4.8.6/include/Qt/q3signal.h
/usr/local/Trolltech/Qt-4.8.6/include/Qt3Support/q3signal.h
/usr/realtime-2.6.32-122-rtai/include/rtai_signal.h
/usr/share/doc/libglib2.0-doc/gobject/chapter-signal.html
/usr/share/doc/libglib2.0-doc/gobject/signal.html
/usr/share/qt4/doc/html/q3signal.html
/usr/src/linux-headers-2.6.32-122/arch/alpha/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/arm/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/avr32/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/blackfin/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/cris/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/frv/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/h8300/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/ia64/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/m32r/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/m68k/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/microblaze/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/mips/include/asm/compat-signal.h
/usr/src/linux-headers-2.6.32-122/arch/mips/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/mn10300/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/parisc/include/asm/compat_signal.h
/usr/src/linux-headers-2.6.32-122/arch/parisc/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/powerpc/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/s390/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/score/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/sh/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/sparc/include/asm/compat_signal.h
/usr/src/linux-headers-2.6.32-122/arch/sparc/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/x86/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/arch/xtensa/include/asm/signal.h
/usr/src/linux-headers-2.6.32-122/include/asm-generic/audit_signal.h
/usr/src/linux-headers-2.6.32-122/include/asm-generic/signal.h
/usr/src/linux-headers-2.6.32-122/include/linux/signal.h
/usr/src/linux-headers-2.6.32-122-rtai/signal.h   <------------ I have create This but not work if put it (signal.h) in my comp heather
/usr/src/linux-headers-2.6.32-122-rtai/include/linux/signal.h   <------------ I have create This but not work if put it (signal.h) in my comp heather
k1@k1-desktop:~$
I not have other ideas for solve my problem now. Your example is ok but I need lauch unix signal from my comp not receive it. At any case I'm unable to compile your code .... I think for bad symlink.
Last edit: 04 Sep 2014 22:51 by bkt.
  • bkt
  • Platinum Member
  • Platinum Member
04 Sep 2014 22:34 #50767 by bkt
For example if I use #include "signal.h" ... or other standard library ... i have this output during the compiling.
us definition
In file included from ./signal.h:79,
                 from /tmp/tmpXmOawi/myUNIXsignal-sender.c:60:
./bits/siginfo.h:166:1: warning: "ILL_PRVREG" redefined
In file included from /usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/siginfo.h:8,
                 from include/linux/signal.h:5,
                 from include/linux/sched.h:73,
                 from /usr/include/linuxcnc/rtapi.h:210,
                 from /tmp/tmpXmOawi/myUNIXsignal-sender.c:29:
include/asm-generic/siginfo.h:166:1: warning: this is the location of the previous definition
./bits/siginfo.h:168:1: warning: "ILL_COPROC" redefined
include/asm-generic/siginfo.h:167:1: warning: this is the location of the previous definition
./bits/siginfo.h:170:1: warning: "ILL_BADSTK" redefined
include/asm-generic/siginfo.h:168:1: warning: this is the location of the previous definition
./bits/siginfo.h:176: error: expected identifier before ‘(’ token
./bits/siginfo.h:177:1: warning: "FPE_INTDIV" redefined
include/asm-generic/siginfo.h:174:1: warning: this is the location of the previous definition
./bits/siginfo.h:179:1: warning: "FPE_INTOVF" redefined
include/asm-generic/siginfo.h:175:1: warning: this is the location of the previous definition
./bits/siginfo.h:181:1: warning: "FPE_FLTDIV" redefined
include/asm-generic/siginfo.h:176:1: warning: this is the location of the previous definition
./bits/siginfo.h:183:1: warning: "FPE_FLTOVF" redefined
include/asm-generic/siginfo.h:177:1: warning: this is the location of the previous definition
./bits/siginfo.h:185:1: warning: "FPE_FLTUND" redefined
include/asm-generic/siginfo.h:178:1: warning: this is the location of the previous definition
./bits/siginfo.h:187:1: warning: "FPE_FLTRES" redefined
include/asm-generic/siginfo.h:179:1: warning: this is the location of the previous definition
./bits/siginfo.h:189:1: warning: "FPE_FLTINV" redefined
include/asm-generic/siginfo.h:180:1: warning: this is the location of the previous definition
./bits/siginfo.h:191:1: warning: "FPE_FLTSUB" redefined
include/asm-generic/siginfo.h:181:1: warning: this is the location of the previous definition
./bits/siginfo.h:197: error: expected identifier before ‘(’ token
./bits/siginfo.h:198:1: warning: "SEGV_MAPERR" redefined
include/asm-generic/siginfo.h:187:1: warning: this is the location of the previous definition
./bits/siginfo.h:200:1: warning: "SEGV_ACCERR" redefined
include/asm-generic/siginfo.h:188:1: warning: this is the location of the previous definition
./bits/siginfo.h:206: error: expected identifier before ‘(’ token
./bits/siginfo.h:207:1: warning: "BUS_ADRALN" redefined
include/asm-generic/siginfo.h:194:1: warning: this is the location of the previous definition
./bits/siginfo.h:209:1: warning: "BUS_ADRERR" redefined
include/asm-generic/siginfo.h:195:1: warning: this is the location of the previous definition
./bits/siginfo.h:211:1: warning: "BUS_OBJERR" redefined
include/asm-generic/siginfo.h:196:1: warning: this is the location of the previous definition
./bits/siginfo.h:217: error: expected identifier before ‘(’ token
./bits/siginfo.h:218:1: warning: "TRAP_BRKPT" redefined
include/asm-generic/siginfo.h:206:1: warning: this is the location of the previous definition
./bits/siginfo.h:220:1: warning: "TRAP_TRACE" redefined
include/asm-generic/siginfo.h:207:1: warning: this is the location of the previous definition
./bits/siginfo.h:226: error: expected identifier before ‘(’ token
./bits/siginfo.h:227:1: warning: "CLD_EXITED" redefined
include/asm-generic/siginfo.h:215:1: warning: this is the location of the previous definition
./bits/siginfo.h:229:1: warning: "CLD_KILLED" redefined
include/asm-generic/siginfo.h:216:1: warning: this is the location of the previous definition
./bits/siginfo.h:231:1: warning: "CLD_DUMPED" redefined
include/asm-generic/siginfo.h:217:1: warning: this is the location of the previous definition
./bits/siginfo.h:233:1: warning: "CLD_TRAPPED" redefined
include/asm-generic/siginfo.h:218:1: warning: this is the location of the previous definition
./bits/siginfo.h:235:1: warning: "CLD_STOPPED" redefined
include/asm-generic/siginfo.h:219:1: warning: this is the location of the previous definition
./bits/siginfo.h:237:1: warning: "CLD_CONTINUED" redefined
include/asm-generic/siginfo.h:220:1: warning: this is the location of the previous definition
./bits/siginfo.h:243: error: expected identifier before ‘(’ token
./bits/siginfo.h:244:1: warning: "POLL_IN" redefined
include/asm-generic/siginfo.h:226:1: warning: this is the location of the previous definition
./bits/siginfo.h:246:1: warning: "POLL_OUT" redefined
include/asm-generic/siginfo.h:227:1: warning: this is the location of the previous definition
./bits/siginfo.h:248:1: warning: "POLL_MSG" redefined
include/asm-generic/siginfo.h:228:1: warning: this is the location of the previous definition
./bits/siginfo.h:250:1: warning: "POLL_ERR" redefined
include/asm-generic/siginfo.h:229:1: warning: this is the location of the previous definition
./bits/siginfo.h:252:1: warning: "POLL_PRI" redefined
include/asm-generic/siginfo.h:230:1: warning: this is the location of the previous definition
./bits/siginfo.h:254:1: warning: "POLL_HUP" redefined
include/asm-generic/siginfo.h:231:1: warning: this is the location of the previous definition
./bits/siginfo.h:274: error: redefinition of ‘struct sigevent’
./bits/siginfo.h:293: error: conflicting types for ‘sigevent_t’
include/asm-generic/siginfo.h:272: note: previous declaration of ‘sigevent_t’ was here
./bits/siginfo.h:302: error: expected identifier before numeric constant
./bits/siginfo.h:303:1: warning: "SIGEV_SIGNAL" redefined
include/asm-generic/siginfo.h:242:1: warning: this is the location of the previous definition
./bits/siginfo.h:305:1: warning: "SIGEV_NONE" redefined
include/asm-generic/siginfo.h:243:1: warning: this is the location of the previous definition
./bits/siginfo.h:307:1: warning: "SIGEV_THREAD" redefined
include/asm-generic/siginfo.h:244:1: warning: this is the location of the previous definition
./bits/siginfo.h:310:1: warning: "SIGEV_THREAD_ID" redefined
include/asm-generic/siginfo.h:245:1: warning: this is the location of the previous definition
In file included from /tmp/tmpXmOawi/myUNIXsignal-sender.c:60:
./signal.h:84: error: redefinition of typedef ‘__sighandler_t’
include/asm-generic/signal-defs.h:18: note: previous declaration of ‘__sighandler_t’ was here
./signal.h:193:1: warning: "sigmask" redefined
In file included from include/linux/sched.h:73,
include/linux/signal.h:89:1: warning: this is the location of the previous definition
./signal.h:222: error: conflicting types for ‘sigemptyset’
include/linux/signal.h:154: note: previous definition of ‘sigemptyset’ was here
./signal.h:225: error: conflicting types for ‘sigfillset’
include/linux/signal.h:166: note: previous definition of ‘sigfillset’ was here
./signal.h:228: error: expected ‘)’ before ‘?’ token
./signal.h:231: error: expected ‘)’ before ‘?’ token
./signal.h:234: error: expected ‘)’ before ‘?’ token
./signal.h:239: error: conflicting types for ‘sigisemptyset’
include/linux/signal.h:72: note: previous definition of ‘sigisemptyset’ was here
In file included from ./signal.h:252,
./bits/sigaction.h:26: error: redefinition of ‘struct sigaction’
./bits/sigaction.h:54:1: warning: "SA_NOCLDSTOP" redefined
In file included from include/linux/signal.h:4,
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:98:1: warning: this is the location of the previous definition
./bits/sigaction.h:55:1: warning: "SA_NOCLDWAIT" redefined
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:99:1: warning: this is the location of the previous definition
./bits/sigaction.h:56:1: warning: "SA_SIGINFO" redefined
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:100:1: warning: this is the location of the previous definition
./bits/sigaction.h:59:1: warning: "SA_ONSTACK" redefined
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:101:1: warning: this is the location of the previous definition
./bits/sigaction.h:60:1: warning: "SA_RESTART" redefined
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:102:1: warning: this is the location of the previous definition
./bits/sigaction.h:61:1: warning: "SA_NODEFER" redefined
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:103:1: warning: this is the location of the previous definition
./bits/sigaction.h:63:1: warning: "SA_RESETHAND" redefined
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:104:1: warning: this is the location of the previous definition
./signal.h:255: error: conflicting types for ‘sigprocmask’
include/linux/signal.h:243: note: previous declaration of ‘sigprocmask’ was here
In file included from ./signal.h:339,
./bits/sigcontext.h:29: error: redefinition of ‘struct _fpreg’
./bits/sigcontext.h:35: error: redefinition of ‘struct _fpxreg’
./bits/sigcontext.h:42: error: redefinition of ‘struct _xmmreg’
./bits/sigcontext.h:51: error: redefinition of ‘struct _fpstate’
./bits/sigcontext.h:82: error: redefinition of ‘struct sigcontext’
In file included from ./signal.h:356,
./bits/sigstack.h:36: error: expected identifier before numeric constant
./bits/sigstack.h:37:1: warning: "SS_ONSTACK" redefined
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:114:1: warning: this is the location of the previous definition
./bits/sigstack.h:39:1: warning: "SS_DISABLE" redefined
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:115:1: warning: this is the location of the previous definition
./bits/sigstack.h:51: error: redefinition of ‘struct sigaltstack’
./bits/sigstack.h:55: error: conflicting types for ‘stack_t’
/usr/src/linux-headers-2.6.32-122-rtai/arch/x86/include/asm/signal.h:184: note: previous declaration of ‘stack_t’ was here
make[2]: *** [/tmp/tmpXmOawi/myUNIXsignal-sender.o] Error 1
make[1]: *** [_module_/tmp/tmpXmOawi] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
make: *** [modules] Error 2
k1@k1-desktop:~$
  • bkt
  • Platinum Member
  • Platinum Member
04 Sep 2014 22:35 #50768 by bkt
  • bkt
  • Platinum Member
  • Platinum Member
04 Sep 2014 22:47 - 04 Sep 2014 22:49 #50771 by bkt
If I compile this simple progrma whit g++ test1.c -o test1 ... the compile is ok and the axis + test1.c + my qt program work perfectly ....
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <errno.h>
#include <signal.h>
int main(void)
    kill(17175, SIGUSR1);
    printf("\n signal send \n");
    return 0;
I try to make this simple thing but using a linuxcnc comp that grab motion.in-position or axis.1.in-position myhal.h signal ..... I hope I was clear ... my English is bad I admit.
I try to not use ncg file at all.
Last edit: 04 Sep 2014 22:49 by bkt.
04 Sep 2014 22:56 #50773 by ArcEye
Just stuff as it occured to me, not had a chance to look through properly, but this jumped out
You have effectively re-defined kill and it calls itself recursively.
It also takes arguments and then ignores them anyway.
Just for the sake of sanity I would call it kill_local or something.
perhaps
int local_kill ( )
int retval = kill(15962, SIGUSR1);
return retval;
